MP_customized Posted December 25, 2020 Share Posted December 25, 2020 Hi everybody MP in the house!   This time a epic co-op with MSI, AMD, Cooler Master, Viper Gaming, cablemod and Bitspower and Remedy Entertainment... thanks for the support! Based on the brilliant game 'CONTROL' where you control some freaking forces to take back control of the world and set things straight ones and for all!  Like always... be ready for an epic ride!       Link to comment Share on other sites More sharing options...
MP_customized Posted December 25, 2020 Author Share Posted December 25, 2020 (edited) To kick things off and check the hardware used in this SFF tower MOD   The base of this MOD is what i think a very interesting designed SFF case of Cooler Master Masterbox NR200P! they made it small yet very dynamic... just the way i like it ! For hardware we use MSI, AMD and Viper Gaming and cooling all Bitspower custom water cooling.  Specs Case: Cooler Master Masterbox NR200 P Mobo: MSI B550 Gaming Edge WifFi CPU: AMD 3950X RAM: Patriot Viper Black Out 32GB 3200MHZ GPU: MSI AMD Radeon 5700  M.2: Patriot Viper 512GB RGB PSU: Cooler Master V850 SFX Gold with custom cablemod power cables. all Cooled down with custom watercooling loop provide by Bitspower and som sweet Master Fans MF120 HALO.    Edited February 1, 2021 by MP_customized Link to comment Share on other sites More sharing options...
MP_customized Posted December 25, 2020 Author Share Posted December 25, 2020 Like always I start by dismantling the case and look how the case itself i mend to be used and what the possibility's are... Sometimes I don't have any plan ready in my mind and just let my imagination work, i also played the game to get some inspiration and boy what a ride it was! Of course the flash of inspiration came in the end where i was playing the very dynamic end scene! My eyes dropped on the dark cave like walls of an alien world and the futuristic building BAM! I had enough of inspiration for the entire build!        Link to comment Share on other sites More sharing options...
MP_customized Posted December 25, 2020 Author Share Posted December 25, 2020 With the very dynamic end of the game i was still pumped and decided to flip the case inside out and put the front down and the back Up! I also modded the interior mobo tray and made it more central located so the Mobo and the GPU where much beter visible as they are facing the outside of the case now instead of blocking each others view.  Some rivets popped and some Dremel Worx... et voila! the base was set! Pre mounting the hardware and cooling components to check the dimensions and YES... perfect fit!    Link to comment Share on other sites More sharing options...
MP_customized Posted December 25, 2020 Author Share Posted December 25, 2020 360 View !  https://photos.app.goo.gl/TKfAvT3BFBqea3oS8  Link to comment Share on other sites More sharing options...
MP_customized Posted December 25, 2020 Author Share Posted December 25, 2020 (edited) After the base was set it was time for the external covers to be designed and 3D printed, I used the inspiration of the gameplay to make this crazy 3D vertical bars wit splines and offset's to make a Unique pattern that suits the game well. It also works as the exhaust shroud (yes exhaust) as this build has a back air intake... nobody said you always need the air intake at the front lol. The holes and cavity's in the design make it possible for the air to escape easy and let the light shine true in a mystic way. (seen later in the progress)  This Is V1.0 the next one will be more refined with the usb ports and power button integrated.         ââ--------------------------------------- Fast Forward several weeks and personal projects later... BAMM there's the deadline incoming!!   Edited February 2, 2021 by MP_customized Link to comment Share on other sites More sharing options...
MP_customized Posted January 31, 2021 Author Share Posted January 31, 2021 (edited) Well Here we Go ... Enjoy Project -=Gravity Control=-   Specs Case: Cooler Master Masterbox NR200 P Mobo: MSI B550 Gaming Edge WifFi CPU: AMD 3950X RAM: Patriot Viper Black Out 32GB 3200MHZ GPU: MSI AMD Radeon 5700  M.2: Patriot Viper 512GB RGB PSU: Cooler Master V850 SFX Gold with custom cablemod power cables. all cooled down with custom watercooling loop provide by Bitspower and 2* CM MF120 HALO\  Dimentions: 380mm high * 180mm wide * 280mm deep = 19.1 Ltr Small & Mighty AWARD     Edited February 1, 2021 by MP_customized Link to comment Share on other sites More sharing options...
MP_customized Posted January 31, 2021 Author Share Posted January 31, 2021 Link to comment Share on other sites More sharing options...
MP_customized Posted January 31, 2021 Author Share Posted January 31, 2021 1 Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
