Tkeen Posted January 28, 2021 Author Share Posted January 28, 2021 4 mounting slots for 2.5-inch drives are enough for me in the case. 1 seat is available as standard. For three more, a metal plate was made with a convenient connection. Theoretically in this case it is possible to arrange 8 or 12 disks in this way. It’s a pity there’s not so many =)) Link to comment Share on other sites More sharing options...
Tkeen Posted January 28, 2021 Author Share Posted January 28, 2021 Finished the most difficult work with metal. Further, only the main assembly. The case has become much heavier, also solid and stable. Photos of this stage. To be continued (day or two). Link to comment Share on other sites More sharing options...
Tkeen Posted January 29, 2021 Author Share Posted January 29, 2021 Adding lighting to waterblocks. Link to comment Share on other sites More sharing options...
Tkeen Posted January 29, 2021 Author Share Posted January 29, 2021 (edited) 7. Assembly. Edited January 29, 2021 by Tkeen Link to comment Share on other sites More sharing options...
Tkeen Posted January 29, 2021 Author Share Posted January 29, 2021 Link to comment Share on other sites More sharing options...
Tkeen Posted January 31, 2021 Author Share Posted January 31, 2021 Аssembly. Front panel is screwed on 6 screws. Link to comment Share on other sites More sharing options...
Tkeen Posted January 31, 2021 Author Share Posted January 31, 2021 Final shots. Just One More Case (Computer) is ready. J.O.M.C is ready. Reservour lighting exceeded my expectations. In the future I will do it in all my mods. This is probably the best case I've ever built. Definitely the hardest. Case weight approx. 33 kg. I want to add orange dye to the liquid and replace with identical 2 140mm fans in the PSU and on the back panel. This will not change the appearance of this case. If you have any questions about this mod, I will try to answer. I hope you enjoyed reading this worklog. Best regards to all modders, Vitaliy (Tkeen). Link to comment Share on other sites More sharing options...
Tkeen Posted January 31, 2021 Author Share Posted January 31, 2021 (edited) Small update. The classic panel with acrylic looks better from the side of hard drives. It turns out that one tempered glass panel is enough for the case. I regret that I did not make 4 disks in one line, it would have looked better and I should have abandoned the factory installation location of the disk. Next time I will do better in case PRO 5 modification. Edited January 31, 2021 by Tkeen Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
