Jump to content
cyberpunk 2077 O.F. [OPEN FRAME]
hi guys, this project involves a cyberpunk 2077 theme customization on the master masterframe 700 case cooler, the components will all be asus rog.
HARDWARE
CASE COOLER MASTER MASTERFRAME 700
ASUS ROG Maximus Z790 HERO
Intel Core i9-14900K
ROG Strix GeForce RTX® 4080 OC Edition 16GB GDDR6X
Corsair 96GB (2x48GB) 5200Mhz DDR5
Asus ROG STRIX 1000W GOLD
SSD FURY Renegade 4TB PCIe 4.0 NVMe
COOLING CUSTOM EKWB
stay tuned....
  • Like 2
Link to comment
Hi guys we start. Creating the LED housing plate, this case has a dual function is a case but also a benchmark houses that can be used as a tester, it has a lot of holes that in my case must be covered, my intention is to build a LED plate with themed graphics.
I make a cardboard shape to calculate the dimensions that I will then go to use EPR the cut on acrylic.
These 2 panels will be superimposed ..
  • Like 1
Link to comment
working on fan grill
little rear panel on the case..
painting the motherboard tray cover.
rear case panels
graphics applied soon
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
Important Information
