Webhallen Config Posted August 12 Author Share Posted August 12 Update! So the design is 99,99% complete and prints for the build has been started. More updates will come as soon as parts start to arrive. Link to comment Share on other sites More sharing options...
Webhallen Config Posted August 19 Author Share Posted August 19 Update! Most of the parts for the build have now been ordered and some as arrived. Almost all of the 3D-prints are done so we can now start to do a mockup and get a sense of the size. The extrusions, nuts and bolts have also arrived so here is some pictures of what its going to look like. 1 Link to comment Share on other sites More sharing options...
Webhallen Config Posted August 26 Author Share Posted August 26 Most of the parts for the main structure have now arrived and some test fitting have been started. 2 Link to comment Share on other sites More sharing options...
Webhallen Config Posted September 2 Author Share Posted September 2 So we have started to assemble the bottom chamber of the case and its coming together nicely. The next thing on the to do list is to cut out the main component plate and assemble the tower. Oh and our CM parts has arrived, we are going with a 1300w SFX unit and some of their Mobius OC fans for the bottom rad. 1 Link to comment Share on other sites More sharing options...
Webhallen Config Posted September 10 Author Share Posted September 10 Update! So all of our parts have now arrived including materials and components so everything is now ready for assembly. Some parts still needs to be cut or printed but everything is here at least The bottom fans + radiator, psu and pump/res-combo have been installed in the bottom chamver so now its time for the IO-cables. The IO cables got installed on their plate and i have started to route them up through the case. Its always tricky to assess what do first in a tight scratch build so lets hope this was the right choice ;D 1 Link to comment Share on other sites More sharing options...
Webhallen Config Posted 6 hours ago Author Share Posted 6 hours ago Update! Some more progress with the build has happend since the last update and the first tubes have been fitted along with cables and a lot of screws and 3d-printed brackets. This build is very complicated in the sense that it has to go together in a very specific order otherwise stuff wont fit. The ammount of space inside the main structure is very limited and screwing screws or drawing cables is very much a challenge. Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
