asgneto Posted August 19, 2009 Share Posted August 19, 2009 I'm getting very inspired with your project. This idea of making a "mobile" with a computer inside is great. I'm waiting for updates... Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 20, 2009 Share Posted August 20, 2009 where's my big brother!? knock, knock?! Link to comment Share on other sites More sharing options...
Cham_E_Lyon TPC Posted August 21, 2009 Share Posted August 21, 2009 I love woodworking! A very brilliant idea indeed! One casemod to watch out for! Link to comment Share on other sites More sharing options...
PaPang Posted August 21, 2009 Share Posted August 21, 2009 whattt - Senior Citizen Modder's Club ( say Slippery the President, wahahahah) Right, off topic but I agree sunnyextremist, slipperyskip for Prez of the SCMC! Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted August 21, 2009 Author Share Posted August 21, 2009 The stanchion tops get their veneer. 24 pieces of veneer measured, cut, glued, clamped, dried, trimmed and sanded. Everything that is not walnut is brushed with flat black latex paint. This includes the lower vent frame shown at bottom right. I'm taking this last opportunity to sand around the stanchion holes while the access is still easy. Thanks for looking! Link to comment Share on other sites More sharing options...
nicky_82uk Posted August 21, 2009 Share Posted August 21, 2009 wow man really coming on nice Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 21, 2009 Share Posted August 21, 2009 Good Morning Bro what's on my mind?! it's a Work Of Art!!! more power bro! Link to comment Share on other sites More sharing options...
Maxession Posted August 24, 2009 Share Posted August 24, 2009 Very nice woodwork, you really are dedicated to make it perfect! Good luck, you indeed really made a little piece of art. Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted August 26, 2009 Author Share Posted August 26, 2009 Thanks everyone for the comments! I had to get in one last "glue drying" photo. The veneer on the bottom of the stanchions marks the end of the veneer work. Pulled the chrome pieces off and slapped on a thick coat of lacquer sanding sealer. The sealer raises the grain to make sanding easier. It saturates the wood so that final lacquer coats go on evenly and also highlights areas that need work like my errant glue marks. For me, the best part of the sealer is that it simulates what the final wood color and grain pattern will look like. Paisley fabric Tabletop angle Naugahyde Almond slate Moss slate More variations coming soon. The final decision on what decorative panel I'll be using will probably be made on Sept 19th. LOL Thanks for looking! Link to comment Share on other sites More sharing options...
PaPang Posted August 26, 2009 Share Posted August 26, 2009 No tin sample? Link to comment Share on other sites More sharing options...
