mstjuan Posted September 10, 2009 Author Share Posted September 10, 2009 i thing it will hold. i gave the undercoat by hand to make it thick. i will send it but i will not make it glossy i will be changing the colour of it but the black undercoat is one of the best since with the black they add some graphite in this paint after this will be and oil base lead paint to hold it more and secure everything. then the can spray. Link to comment Share on other sites More sharing options...
mstjuan Posted September 10, 2009 Author Share Posted September 10, 2009 today's update. i wanted to make the back a little more secure therefore i tough of securing the angles. this is a cut out of the side and angles as a filling i will be using silicon Here is a sample of how i was filling them after applying the silicon i was pressing it against the wall and corners of the back part here is how i applied the sides. More........... Link to comment Share on other sites More sharing options...
mstjuan Posted September 10, 2009 Author Share Posted September 10, 2009 here i started placing the proper components to see how they fit. here above is the main board i will be using. here is the PSU. and here i started dismantling the psu. . Link to comment Share on other sites More sharing options...
mstjuan Posted September 12, 2009 Author Share Posted September 12, 2009 I went shopping this morning and i having great difficulty to find 1 meter sata cables have any tested modding the cables like cutting them and rejoining them ? Link to comment Share on other sites More sharing options...
PaPang Posted September 12, 2009 Share Posted September 12, 2009 I decline, I have never seen longer than 24" and splice them????? Anyone else? Cheers and Saludos Link to comment Share on other sites More sharing options...
mstjuan Posted September 12, 2009 Author Share Posted September 12, 2009 just did it and now i will be testing it they are very but very small wires phew my eyes . i need glasses.. Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted September 12, 2009 Share Posted September 12, 2009 I would have dug up a case eSATA cable and then daisy chained it. I drink too much coffee to do those tiny wire splice jobs. More power to you! Link to comment Share on other sites More sharing options...
mstjuan Posted September 12, 2009 Author Share Posted September 12, 2009 but i can't connect an e-sata to a sata port right? those are different now it's done and i tested with a continuity test via a multi meter and worked . Link to comment Share on other sites More sharing options...
mstjuan Posted September 12, 2009 Author Share Posted September 12, 2009 but i wasted to much time on it just to make it working a stable not fancy but working Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted September 12, 2009 Share Posted September 12, 2009 but i can't connect an e-sata to a sata port right? those are different now it's done and i tested with a continuity test via a multi meter and worked . Male connector on one end and female on the other. It is just an extension cable. I'll let you get back to work. Link to comment Share on other sites More sharing options...
