FrenkieNL Posted August 12, 2009 Share Posted August 12, 2009 Hello Maciel, It is very good to see you here with this amazing project. I am a big fan of you, love your work ! I hope you win ! Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 12, 2009 Author Share Posted August 12, 2009 FrenkieNL Thank you for the words and it is good to know that people admire my work was worth it man Muito obrigado pelas palavras e é bom saber que existe pessoas que admiram meu trabalho valeu mesmo cara Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 13, 2009 Author Share Posted August 13, 2009 I put all Hards trapped in the back so the time is easier to maintain because it removes at once independent of the rest of the body, rather just disconnect some wires and the source who would find where I put? motherboard ASUS EXTREME VGA ATI 4 GB RAM 800 CPU CORE 2 DUO Coloquei todos os hards preso nas costas assim fica mais facil na hora de dar manutenção pois remove tudo de uma vez independente do resto do corpo, bastanto apenas desconectar alguns cabos e a fonte quem será que descobre onde irei colocar? Link to comment Share on other sites More sharing options...
PaPang Posted August 13, 2009 Share Posted August 13, 2009 Ahhh...getting a better idea. Keep the updates coming. BTW, I have seen your mod finished (Campus Party Brazil 2009), but of course with your log, I understand it now. Saludos/Cheers Link to comment Share on other sites More sharing options...
VALKYRIE Posted August 13, 2009 Share Posted August 13, 2009 Very well done , congratulations ,I myself have added the noses to my 140mm Yate-Loon fans and is very very difficult to find the noses with the exact properly size Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 13, 2009 Author Share Posted August 13, 2009 Ahhh...getting a better idea. Keep the updates coming. BTW, I have seen your mod finished (Campus Party Brazil 2009), but of course with your log, I understand it now.Saludos/Cheers then you saw it? kkkkk made some changes to the Cooler Master CONTEST,, you'll like it! I was in your country when I was at EL SALVADOR, but I guess if you see, ruined the surprise. PAPANG kkkkk big hug então você viu né? kkkkk fiz algumas mudanças para o COOLER MASTER CONTEST ,, VoCê VAI GOSTAR !! estive em seu paÃs quando fui pra EL SALVADOR , mas queria ver se você advinhava , estragou a surpresa .PAPANG kkkkk grande abraço Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 13, 2009 Author Share Posted August 13, 2009 Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 14, 2009 Author Share Posted August 14, 2009 Look at the source where it will be, and chose to put all Hards on a single piece of Morphius, as well as built it had to think about as easy to dismantle it's time to exchange a piece for example, and the locks in back help and very quickly in the opening and handling with ease. OLha a fonte onde irá ficar, bem optei por colocar todos os HARDS em uma peça só do MORPHIUS, pois além de construi-lo tinha que pensar na facilidade de como desmonta-lo na hora de trocar uma peça por exemplo, e as travas nas costas ajudam e muito na abertura rapida e o manuseio com facilidade. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 15, 2009 Author Share Posted August 15, 2009 Well now that you saw where it will be all assembled Hards, I will from now to the body and head of Morphius to the finish line of mounting and finishing Bem agora que vocês viram onde irá ficar todos os hards montados, irei partir agora para o corpo e cabeça de MORPHIUS, para o termino da linha de montagem e acabamento Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 16, 2009 Author Share Posted August 16, 2009 This casemod ALIEN SKUUL did it in 2008, but the straight to see how the project is finalized, this casemod is PAPANG you see the possibilities and details that can work in a Modding hugs! Esse casemod ALIEN SKUUL fiz ele em 2008 , mas da pra ver direitinho como fica o projeto finalizado , PAPANG esse casemod é para você ver as possibilidades e os detalhes que se pode trabalhar em um MODDING abraços!! Link to comment Share on other sites More sharing options...
