Jump to content
Project: Tribal's Cube
TribalMind
Hi All,
I want to share my worklog on my ongoing modding project Tribal's Cube
It is inspired on the Cube movies and the Hellraiser puzzlebox
I started this year in april with the design and the building of an 3D model in Solid Works to get the correct plecement of parts and measurements
After some 2 months of designing drawing and designing the electronics, I was ready to stat the build
I'm building now for 3 months and the cube structure and finishing is ready
Also the 100 RGB LED's are functioning (lateron it will become 200 LED's)
status So far:
Fully functioning PC inside
Full ATX motherboard fits
Normal PSU fits
space for at least 2 HDD's
Watercooled
100 RGB LED's controlled by microcontroller to change the color of the cube
mechanics for raising and lowering of the drives are in place
To be done
Round and square drivebays with RGB Leds
All cube functions work upon touch (electronics ready, software needs work)
Placement of controllerboards and internal wiring for touch and LEDs
Touch-Controlpanel (front hexagon) with amplifier board inside
Link to comment
  • 2 weeks later...
  • Create New...
Important Information
