AeGis Posted September 16, 2009 Author Share Posted September 16, 2009 Link to comment Share on other sites More sharing options...
PaPang Posted September 17, 2009 Share Posted September 17, 2009 Looks like decoration from the ancient temples of Siam. I appreciate art and hope your parts look fantastic on your mod. Kudos to you . Cheers and Saludos Link to comment Share on other sites More sharing options...
AeGis Posted September 17, 2009 Author Share Posted September 17, 2009 Update now begin assembly of a different color pattern are close to will be any increase, but the problem has made a small version of the case is unable to successfully pass a call to see the same major version. But I have to edit line by to pass after the break. Translator to English By Google Link to comment Share on other sites More sharing options...
masbuskado Posted September 22, 2009 Share Posted September 22, 2009 Looking good!!! keep it up! Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 22, 2009 Share Posted September 22, 2009 Looking good!!!keep it up! Go, go, go Sir AeGis... keep it coming!!! Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 24, 2009 Share Posted September 24, 2009 มาà¸à¸±à¸šà¸žà¸µà¹ˆà¸Šà¸²à¸¢à¹„ม่มีเวลามาà¸à¹„ปในขณะนี้ Link to comment Share on other sites More sharing options...
AeGis Posted September 25, 2009 Author Share Posted September 25, 2009 Back and forth update after 1-2 days to do the same definition of the case or when combined with various wires pass milling using cables 10 baht per meter (about 0.30 dollars) arrived. Match separate line out and then rip out the copper insert out ครับ. Then remove the sheaths that merge point add the line pass. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 25, 2009 Share Posted September 25, 2009 +1 for the U channel Sir AeGis Link to comment Share on other sites More sharing options...
AeGis Posted September 25, 2009 Author Share Posted September 25, 2009 next day to Update Link to comment Share on other sites More sharing options...
AeGis Posted September 25, 2009 Author Share Posted September 25, 2009 +1 for the U channel Sir AeGis Link to comment Share on other sites More sharing options...
