labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 Purchased a aluminum billet fan grill from MNPCTECH.COM I sanded and painted it semi-gloss black spray paint. I used a xigmatek case fan with this attached to my HDD cage. I spray painted the HDD cage black and adjusted the HDD Cage so it would fit forward in the case and screwed it down. See picture above of fan on with gril. Link to comment Share on other sites More sharing options...
labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 MORE PARTS MSI 790FX-GD70 Motherboard OCZ DDR3 RAM 8GB (sets of Dual Channel DDR3 10666 1333Mhz AMD Edition RAM) WINDOWS VISTA ULTIMATE 64 BIT 2 graphics cards in Crossfire HD4850 Sapphire 1GB DDR3 Ram OCZ Memory fan cooler Link to comment Share on other sites More sharing options...
labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 WATER COOLING DANGER DEN XFLOW Radiator Zalman Fan Controller, LG Blu-Ray player, XSPC Dual 5.25" Bay Reservoir - Black Link to comment Share on other sites More sharing options...
PaPang Posted September 15, 2009 Share Posted September 15, 2009 Great look on the paint, but a question, is the black on the outer part the original case paint just super buffed? I like the Dakota motif on the side panel. You might consider no more than 800 X 600 max. (it eats up a little part of the photo, but fills the page without having to click), great work doesn't have to so big to be appreciated. Good luck and the Best. Cheers and Saludos Link to comment Share on other sites More sharing options...
labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 SIDE PANEL MOD Took off the side fan and painted the panel with high gloss black krylon spray paint. wetsand, 3m compound, and 3m hand glaze on side panels. added 1/8" smoke plexiglass drilled holes for location. cut hole for fan with dremel. added Xigmatek 120mm fan with FLAME grill by MNPCTECH.COM THen I found a buffalo vinyl sticker on EBAy and used it plus I am waiting for new Dakota letters from EBAy. Link to comment Share on other sites More sharing options...
labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 SMALLER PICTURES SORRY I spray painted only the grey plastic panels with high gloss Black krylon fusion. I did not have to wet sand them too much. but i did put rubbing compound on them and then i put on hand glaze and then finished with carnuba wax. The plastic pieces were harder to paint due to the spray paint. i dont have a spray gun. but despite that, they did turn out fine. Link to comment Share on other sites More sharing options...
labellel67 Posted September 15, 2009 Author Share Posted September 15, 2009 Flame Grill from MNPCTECH.COM 80mm size. I used my dremel and shaved off the sides that are used to attach the grill. Next I will paint it satin black and my reservoir burnt orange. Link to comment Share on other sites More sharing options...
labellel67 Posted September 19, 2009 Author Share Posted September 19, 2009 Paint the reservoir Used Burnt Copper by Duplicolor Metalspecks. Link to comment Share on other sites More sharing options...
labellel67 Posted September 19, 2009 Author Share Posted September 19, 2009 Link to comment Share on other sites More sharing options...
labellel67 Posted September 19, 2009 Author Share Posted September 19, 2009 SLEEVED THE 24 PIN EXTENSION BLACK WITH BLACK HEATSHRINK/Sleeve Link to comment Share on other sites More sharing options...
