Rudieman Posted December 9, 2009 Share Posted December 9, 2009 I wasn't planning on watching this movie but your mod here persuaded me:) ...and I'm glad I did! Looking good so far Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 9, 2009 Author Share Posted December 9, 2009 Good to hear, Glad you liked the movie too! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 10, 2009 Author Share Posted December 10, 2009 Once everything is assembled, all of the details like weathering, graphics, and effects can be airbrushed on the exterior like the concept drawing. Right side panel, the hole will have burned effect airbrushed on later Left side panel Cooler Master sent over 3x 230mm red led fans, 1x for front intake, 2x top exhaust The 840 normally comes with Black frame 230mm fans, no leds. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 10, 2009 Author Share Posted December 10, 2009 I've had this .5" x 25" flexible conduit lying around, I've always wanted to use it for routing cables. It fits the industrial theme. I've also got .25" i.d. flexible conduit. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 10, 2009 Author Share Posted December 10, 2009 Flexible conduit cables! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 11, 2009 Author Share Posted December 11, 2009 Here is the Prawn canister from the movie. My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover. Once it's painted and the window is darkened a bit, it should look eerie. canister back cover for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic with a heat gun, but more on that later! http://www.mnpctech.com/acrylic_colored ... dows1.html Link to comment Share on other sites More sharing options...
Delusion77 Posted December 12, 2009 Share Posted December 12, 2009 those side panels look SICK Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 12, 2009 Author Share Posted December 12, 2009 Thank you for tuning in and commenting! I made the canister's window today. Using a heat gun to bend the Lexan. Forming the arc in window by pressing heated piece on the Aluminum rod. It's HOT! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 12, 2009 Author Share Posted December 12, 2009 4" UV cold cathode. UV looks Blue in the photos The window will be painted to look murky, like the original canister The canister will be painted tommorow Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 13, 2009 Author Share Posted December 13, 2009 Orange Bezel with White intake plate installed. I cannot wait to grunge it up! Link to comment Share on other sites More sharing options...
