Maxession Posted December 13, 2009 Share Posted December 13, 2009 Starting to look better and better! Gota say it again, nice colors! Front panel looks great with the fan behind! Gonna place a filter behind it?If so, paint it white! lol Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 14, 2009 Author Share Posted December 14, 2009 I don't think Christopher would care, did you see his shack..pretty messy I chose the 1/4" socket head screws, these are fastened into the side panels Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 14, 2009 Author Share Posted December 14, 2009 The Prawn canister can't remain Silver. I prepped the aluminum surface with medium grit sandpaper, applied Black SEM self etching primer, then headed over to Brad's so he could apply the Pewter base color coat. Brad did all of the Prawn canister graphics by applying vinyl film and cutting the designs free hand with an Exacto, he used the movie still for reference. Look Ma, No vinyl film plotter or software! Prawn canister window was tinted like original Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 15, 2009 Author Share Posted December 15, 2009 Today while at the shop I cut some 1/8" thick mirrored acrylic sheets to encase the 5.25 bay around the canister location. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 15, 2009 Author Share Posted December 15, 2009 I used the Scotch 4010 Heavy Duty Tape to adhere onto the mirrored acrylic http://www.mnpctech.com/scotch_4010_tap ... _gods.html Link to comment Share on other sites More sharing options...
Delusion77 Posted December 15, 2009 Share Posted December 15, 2009 I want to buy this case! gets better and perter each update Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 16, 2009 Author Share Posted December 16, 2009 PRAWN RUSTED GPU! Watch E.E.L. Embiense demonstrate how to use the Sophisticated Finishes products for adding a rust effect to your Mods. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 16, 2009 Author Share Posted December 16, 2009 I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 17, 2009 Author Share Posted December 17, 2009 There will be an MNU logo painted on this optical drive. Christopher likely traded something towards it, so he could view cd rom archived files from MNU perhaps? More rust effects occur.. The new 600W Cooler Master Silent PRO didn't look right in a POS computer, it was treated to "rust lovin" as well. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 17, 2009 Author Share Posted December 17, 2009 Intel Core 2 Duo 3.16 GHz Processor in Intel DX48BT2 Motherboard. I'm looking at this Cooler Master HYPER N620 and wondering ""What Christopher do differently with it?" Link to comment Share on other sites More sharing options...
