MonsterMawd Posted January 22, 2010 Author Share Posted January 22, 2010 District 13?....surething! I dissected the chassis for paint. The top panel with the power switch and I/O is fastened on with plastic tabs, located beneath the top panel. Very easy to remove! The case chassis, just before removing the rear i/o slot covers, noise dampening felt strips for PSU and case feet. Link to comment Share on other sites More sharing options...
Marc Molella Posted January 25, 2010 Share Posted January 25, 2010 Looking good, awaiting more and will be modding an HAF 922 of my own very soon! Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 2, 2010 Author Share Posted February 2, 2010 Awesome! Theyre a great case to work with Link to comment Share on other sites More sharing options...
Marc Molella Posted February 3, 2010 Share Posted February 3, 2010 Awesome! Theyre a great case to work with Yeah I built two systems for family members as christmas presents using the HAF922 and a P55 setup, and I was very impressed with the case, and the space and airflow possibilities! Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 19, 2010 Author Share Posted February 19, 2010 Cool! Mixed Black with Silver metallic for the 922 Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 22, 2010 Author Share Posted February 22, 2010 I had spare time to prep the chassis for the primer coat last night. I'm using a Red Scotchbrite pad to scuff the surface. Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 27, 2010 Author Share Posted February 27, 2010 I'll be installing 2 of these aluminum 120mm Turbine Fans These are 2000 rpm, 79.4 cfm @ 30 dBA Link to comment Share on other sites More sharing options...
Ragdollcatman Posted March 2, 2010 Share Posted March 2, 2010 Do you make these as one off items or commercially? Wouldn't mind getting something like this. Have you done anything for the Cosmos 1000 case? If so, and its commercial, I wouldn't mind getting it as my Cosmos 1000 is no longer used due to it not having good air flow. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 14, 2010 Author Share Posted March 14, 2010 Better open up the rear exhaust for improved airflow as well before the chassis gets painted. Rear exhaust grill on the HAF 922 chassis Low tack masking tape (Scotch brand Painter's tape) 120mm Nautilus Fan grill http://www.mnpctech.com/120mm_Overkill_Fan_Grills.html Trace the inner opening of the 120mm Overkill Nautilus fan grill Using Jigsaw with 18 TPI metal cutting blade. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 17, 2010 Author Share Posted March 17, 2010 Lets turn things upside down on the HAF. The bottom of the HAF gets modified with this 140mm billet grill. The slotted insert is removable, which makes tracing the inside easy. Screen material I cannibalized from another case filters out the dirt and dust. Link to comment Share on other sites More sharing options...
