MonsterMawd Posted March 19, 2010 Author Share Posted March 19, 2010 I applied the base coat on the HAF 922 chassis last night, this is Rustoleum's Grey self etching primer. It reminded me of Military Grey.. I love the color. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 20, 2010 Author Share Posted March 20, 2010 We made a stencil using the SF from the Stompfest event logo. It created a weird pattern, I call it Alien camouflage ..heh Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 21, 2010 Author Share Posted March 21, 2010 Assembly started with the HD cages, I/O covers, custom feet and 140mm fan Dusted the tops of the feet from 20" away with Black Self-etching primer... Painted the 140mm fan grill.. should have done same effect, looking at it now.. oh welly! Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 22, 2010 Author Share Posted March 22, 2010 I've gotta get it done soon, it's the main prize for the Stompfest LAN Event, April 10th - 11th in Indianapolis, http://www.stompfest.com/index.php?pageid=lanreg Today I ordered COOLER MASTER eXtreme Power Plus 500W Power Supply today, so they could power up any lights or fans I've installed while it's on display. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 22, 2010 Author Share Posted March 22, 2010 I really liked the speckled paint effect on the feet, so I'm repeating it on the rear 120mm Nautilus rear fan grill, http://www.mnpctech.com/120mm_Overkill_Fan_Grills.html I masked off the face of the Nautilus grill, then painted the inner walls of the openings with Black self etching primer. flipped it over, and painted the backside as well. I then removed the masking tape and held the can roughly 16" away from the grill and sprayed the perimeter of it. This is how you achieve the speckled paint effect. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 23, 2010 Author Share Posted March 23, 2010 The exterior is getting painted the sample I posted earlier, Silver Grey Metallic. I applied Matte Clear over the primer on the chassis. Here is the XIGMATEK XLF-F1254 120mm White LED Case Fans. These are rated 1500 RPM @ 61 CFM. Noise level is 20 dbA Link to comment Share on other sites More sharing options...
Mr. Miyagi Posted March 23, 2010 Share Posted March 23, 2010 Looking good so far sir. The speckled fan guards look sick. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 27, 2010 Author Share Posted March 27, 2010 Thank you Miyagi ! The Overkill "Nautilus" 120mm fan grill with XIGMATEK XLF-F1254 120mm fan installed. Overkill fan grills here, http://www.mnpctech.com/120mm_Overkill_Fan_Grills.html Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 29, 2010 Author Share Posted March 29, 2010 Ok, here is the custom HAF 922 front bezel and fan grills after receiving 4th coat of Charcoal Grey Metallic paint today. The finish on the bezel will buffed out. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 29, 2010 Author Share Posted March 29, 2010 Thanks for the comments! This paint color has become one of my all time favs Link to comment Share on other sites More sharing options...
