MonsterMawd Posted March 29, 2010 Author Share Posted March 29, 2010 Here is the HAF 922 panel before executing the window and paint. Right side panel, we'll be commemorating the 2010 Stompfest event with some artwork on this panel Link to comment Share on other sites More sharing options...
bob808 Posted March 29, 2010 Share Posted March 29, 2010 wow! very nice job! Can't wait for the finish Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 30, 2010 Author Share Posted March 30, 2010 Glad you like it bob808! Thanks you for commenting Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 31, 2010 Author Share Posted March 31, 2010 I started installing the Acoustical foam in the HAF 922 chassis yesterday, starting on the backboard. It has Adhesive backing for easy installation. It cuts very easily with a scissors or Xacto knife. This foam will help dampen noise generated from inside the 922. http://www.mnpctech.com/Acoustical_Foam_Sheets_PC.html Link to comment Share on other sites More sharing options...
Mr. Miyagi Posted March 31, 2010 Share Posted March 31, 2010 Are you acustamating the whole interior or just parts of it? Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 2, 2010 Author Share Posted April 2, 2010 The whole chassis, will have photo posted soon! Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 6, 2010 Author Share Posted April 6, 2010 The deadline to finish "Overkill 922" is this Thursday, so it can be debuted at the Stompfest LAN Event this weekend,. April 10th - 11th. The final stages are custom paint, custom cable sleeving, sound insulation foam, Enermax cooling fans and Mitron Noise Isolator fan controller. We thought the custom paint should incorporate some Sci-Fi elements with the "SF" logo from Stompfest with some Industrial cues, like this Yellow & Black Hazard area painted over the top panel of the HAF 922. Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 7, 2010 Author Share Posted April 7, 2010 We needed a character that embodied the hardcore LAN Gamer. He knows how to build a killer system. Enjoys annihilating Noobs on their inherited Emachines. He likes getting jacked up on Caffeinated Energy Drinks and junk Food. You get the idea... Thats how we landed on the implementation of this "LAN Terminator" dude with the "SF" logo craved into his skull. Hes surrounded by circuits hardwired into the system inside. People should fear the guy that walks into future events with this case. Check out Brad's airbrushed Red and Blue Glowing LEDS, and conduit tubing à la H.R. GIGER. Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 7, 2010 Author Share Posted April 7, 2010 Installed the window and "SF" logo, installed front Xiggy grills U-channel window molding, http://www.mnpctech.com/UChannel.html I use the Clear 3M 4010 Heavy Duty Tape, http://www.mnpctech.com/scotch_4010_tap ... _gods.html Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 8, 2010 Author Share Posted April 8, 2010 Working on final assembly today Link to comment Share on other sites More sharing options...
