MonsterMawd Posted May 31, 2010 Share Posted May 31, 2010 This is the Cooler Master CM 690 case mod project I'm working on. Hmmm.. Cooler Master CM 690, Before Hmmm something is different... Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 2, 2010 Author Share Posted June 2, 2010 5.25 bay and rear I/O plate and 3x I/O shields painted "House of Kolor" Kandy Blue Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 4, 2010 Author Share Posted June 4, 2010 Today I cut a 140MM hole in the chassis floor for the Power Supply Cooling fan Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 6, 2010 Author Share Posted June 6, 2010 I'm using these Black pop-rivets to re-assemble the painted 690 chassis Black Pop Rivets http://www.mnpctech.com/Pop_rivets_for_ ... _case.html Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 9, 2010 Author Share Posted June 9, 2010 We've painted the CM 690's side panels Gloss Black, both the interior and exterior side. The window was cnc milled from 1/8" clear cast acrylic. Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 10, 2010 Author Share Posted June 10, 2010 The 140mm intake in the floor will be relocated to bottom of the chassis, so I've made spacers to raise the 690. These are milled from 3/4" thick aluminum Link to comment Share on other sites More sharing options...
Delusion77 Posted June 10, 2010 Share Posted June 10, 2010 Looks like this is gona be a sexy 1 Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 11, 2010 Author Share Posted June 11, 2010 Glad you like it! Here is the 2x 120mm machined fan/rad grill Mnpctech makes for PPCs. May go with Anodized Black version instead, I'll piece everything together first and decide Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 14, 2010 Author Share Posted June 14, 2010 I will post the Black Anodized 2x120mm grill for comparison. Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 17, 2010 Author Share Posted June 17, 2010 Here is the window shown with Black Anodized 2x120mm Radiator Grill from PPCs Link to comment Share on other sites More sharing options...
