MonsterMawd Posted June 20, 2010 Author Share Posted June 20, 2010 These Black Anodized Thumbscrews look really nice with the custom painted Cooler Master 690 chassis Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 21, 2010 Author Share Posted June 21, 2010 I've had a lot people ask how I made the 140mm fan hole on the bottom, You can use a 5.5" size Hole Saw Attachment. (140mm = 5.51181") Amazon has good selections for 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, HERE Other Hole saw attachment sizes 80mm = 3†hole saw 92mm = 3.5†hole saw 120mm = 4.5†hole saw Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 22, 2010 Author Share Posted June 22, 2010 Here are the Black spacers, back from the Anodizer with 690 rubber feet. These were created to raise the height of the 690, to improve airflow beneath the chassis Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 22, 2010 Author Share Posted June 22, 2010 I installed the CM690 spacers we made from aluminum and factory feet this morning The outter edge of the feet will be flush with the side panels. Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 22, 2010 Author Share Posted June 22, 2010 The access side panel window mounted. Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 23, 2010 Author Share Posted June 23, 2010 Then invidual I'm customizing this case for, wanted to see what the 120mm Enermax Apollish Twister fans looked like on his case, but he can't keep them! I need them for another build. Link to comment Share on other sites More sharing options...
Adam2013 Posted June 25, 2010 Share Posted June 25, 2010 Are you gonna load it up? Your mod looks insane! Really liking the black/blue combo and how you rotated the 5.25" bays! Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 29, 2010 Author Share Posted June 29, 2010 Thank you Adam, and yes, we hope to "load it up" with some nice hardware Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 30, 2010 Author Share Posted June 30, 2010 Here is the other Power Supply he decided to use instead.... for the system in the Cooler master 690 case I'm customizing for SurferJoe. The PSU is SLI ready certified, and comes with both six and eight pin PCIe connectors. The connections at the PSU are specially designed to screw-lock into place so you don’t have to worry about them coming off. KINGWIN Mach 1 ABT-1000MA1S 1000W ATX / BTX SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply Link to comment Share on other sites More sharing options...
Coolone Posted June 30, 2010 Share Posted June 30, 2010 Looks very nice! What is your plan about opening the LG drive - since you have pointed it to the side window? Maybe you would tell us what you have planned for the front side of your case mod? Great work! Link to comment Share on other sites More sharing options...
