Jump to content
HAF 932 Project Classified
LeandroJVarini
The case was purchased with Elyeder friend, so he had no intention of disposing of the case after a few conversations over the same case sent me, very well packaged brand new! and a price that even doubted God! lol.
The project itself is an adaptation of the Coolermaster HAF 932, so that it would in an EVGA X58 SLI Classified 4 Way, which has standard XL-ATX and hence the same is higher than a motherboed ATX.
Customizing the case:
Construction and fitting a NOBO I/O with 10 pci
Trail cuts for cable and fixing other
Remove bays and HD DVD
Construction of the hood to attach the radiator and other parts of the toilet
Cut side window in addition to custom acrylic
Manufacture of a new front
Customization of the ceiling
Montana Gold Series paints painting or powder coating
Watercooler:
Initially
Pump DP-1200 Mod EK
Radiator 360 ST
6x Fan Schytle 3000RPM Ultra Kase
Reservoir Swiftech rev 2.0
GTZ CPU Block Swiftech Mod 1366
Future:
Not revealed
Hardware:
Core I7 920 D0
6GB OCZ Reaper 1866MHZ
GTX 470 280
Antec 1200
Creative X-Fi Titanium Gamer 7.1
500GB 1TB
Future:
Not revealed
Other components and customizations:
Not revealed
Photos:
HAF 932:
Watercooler:
Test done on the same
Fans for Radiator:
Done the same tests
Hardware:
PSU
Motherboard
Memory
Render & PhysX
starting the project.
I did a test to see if the mobo would like inside the case, and as it thought was perfect!
Disassembling the case and testing the position of the radiator at the front where it will be fixed with a hood.
We have the ability to Put a radiator 8 120mm fans on the front.
Let's make Sleeving? Look amount of cables in this case has front panel! Sleeving there!
for now is just that!
Sorry for my bad english!
Link to comment
  • 2 weeks later...
  • Create New...
Important Information
