Nicola Tassiello Posted January 22, 2011 Share Posted January 22, 2011 Another masterpiece in the making and one I look forward to seeing more! Link to comment Share on other sites More sharing options...
kier Posted January 27, 2011 Author Share Posted January 27, 2011 Small Update-------------------Recycling This week a friend of mine, had given my a broken Logitech G15. The idea was to use it for the lcd screen, but when i dismantel it i saw the small plex for the illuminated board Idea !!! Used a bigger piece for the cover Sawn a piece out of it and drilled 3 holes for the bitspower fillport The three Bitspower fillport Swan the acryl from the G15 testing with a green ledstrip Looks like the matrix Put a black vinyl sticker over the transparent acryl and cut small pieces out of it Place it in the haf Shot in the dark 3 fittings installed Everything is gonna be replaced for black fittings and solid tubes Grtzzz. Link to comment Share on other sites More sharing options...
Nicola Tassiello Posted January 27, 2011 Share Posted January 27, 2011 Not only are you're modding but you're trying to create a "Mona Lisa"! Fantastic detailed work. Link to comment Share on other sites More sharing options...
kier Posted January 29, 2011 Author Share Posted January 29, 2011 Not only are you're modding but you're trying to create a "Mona Lisa"! Fantastic detailed work. Thnx, for the nice compliments more detailed work is coming up Link to comment Share on other sites More sharing options...
kier Posted January 29, 2011 Author Share Posted January 29, 2011 Update Today a nice update for Cooler master (and you offcourse) First i wanna thank some friends, who had made the perfect sticker. And i wanna thank Dick hard, he also made this update possible Logo Cooler Master The sticker Sawn a piece of uv-green acryl, and made a slot for the slimline dvd-rw Very carfully placed the sticker and cut the sides To have a nice illuminated cover, Mr. Dick Hard has given my 2 nice glowpads Color is blue, thats why i had placed the uv-green You can cut the glowpads any shape you want placed on the back of the cover Illuminates Coolermaster And illuminates the hole cover, nice effect i think Placed back in de Haf The front almost finished In the dark............ Grtzzz. Link to comment Share on other sites More sharing options...
asgneto Posted January 30, 2011 Share Posted January 30, 2011 Amazing the efect of this glowpads... Where did you found this kits ? Waiting for more updates. Link to comment Share on other sites More sharing options...
kier Posted January 30, 2011 Author Share Posted January 30, 2011 :shock: Amazing the efect of this glowpads... :shock: Where did you found this kits ? Waiting for more updates. They are from Recon- gloplex, a good friend give them to me. Gonna ask him where he get these. To be continued Update: Speed modding Did some nice things this week. Finally received my Acryl and aluminum panels 1mm black aluminum and the panels i was waiting for Uv green 3mm And 5 mm A little idea i had, drawing a mold Then cut out some cardboard Shapping the cpu And the Corsair memory The gpu's and the mold is finished And now the nice part, when i screw this up, i have a big problem, this came out of a hole panel, so really cant screw this up. But with same patience it came out very well, i think Cut out some openings for the cpu cables and motherboard cables And the cover is finished there gonna be black stickers on it, and cut these for a green outline That's it for this weekend. See yah soon again, i hope Link to comment Share on other sites More sharing options...
asgneto Posted January 30, 2011 Share Posted January 30, 2011 Thanks for the info. I searched for the Recon and GloPlex on Google but have not found any information. There is on the packaging the url of their site? If you get any more information I will be grateful. Nice job on the acryl panel, but don't forget that there are other components on the motherboard that need to be cooled. I suggest you to use one or two small fans (40mm) to create some air flow underneath the acrylic. Link to comment Share on other sites More sharing options...
kier Posted February 1, 2011 Author Share Posted February 1, 2011 Thanks for the info.I searched for the Recon and GloPlex on Google but have not found any information. There is on the packaging the url of their site? If you get any more information I will be grateful. Nice job on the acryl panel, but don't forget that there are other components on the motherboard that need to be cooled. I suggest you to use one or two small fans (40mm) to create some air flow underneath the acrylic. Hi mate, Have asked my friend where he bought the pads. and he bought them from a Dutch kind off e-bay site but i coudlnt find them anymore. So i have send Recom a mail, if they know some sellingpoints of the pads Waiting for there reply edit: just received a mail from Recom: just send recom.nl a mail, they can deliver the pads Link to comment Share on other sites More sharing options...
asgneto Posted February 2, 2011 Share Posted February 2, 2011 Hi mate, Have asked my friend where he bought the pads. and he bought them from a Dutch kind off e-bay site but i coudlnt find them anymore. So i have send Recom a mail, if they know some sellingpoints of the pads Waiting for there reply edit: just received a mail from Recom: just send recom.nl a mail, they can deliver the pads Hi kier, I'll send the email to them right now and see how to buy some pads for my future projects. Thank you very much for your help !!!!!! I keep an eye on your project waiting by news. Link to comment Share on other sites More sharing options...
