kier Posted February 18, 2011 Author Share Posted February 18, 2011 Update Hi there, like promised pics by daylight Was a lot of pushing and pulling For the airflow behind the acryl and the motherboard i have placed some nice small fans witch blow air up They blow air against a small metal stripe, and bend the flow down, behind the acryl Works perfectly And i have placed some green strips for the frontbay everything placed in order Have sawn small pieces of green 3mm acryl think it looks nice with the black top But need to frost it some more Cover the behind also Gonna think it over some more And last but not least, the side panel Sawning time Used a 5mm green acryl again Need to be shappen some more And placed it back Looks fine with uv led strips But needs to be placed it in the right direction After this i did some thinking, and think it's a shame that the gpu's are not fully in sight So did some sawning again. Better like this, i think. The idea is to use the green acryl piece i've made, to place it in the other side panel so, to be continued Greetings Link to comment Share on other sites More sharing options...
Papangcun Posted February 18, 2011 Share Posted February 18, 2011 Ah, love the mobo shield and the stealth dvd cover on the front. Very hot glow effects of the green acrylic and lighting. Makes one want to see more! Cheers and Saludos Link to comment Share on other sites More sharing options...
FrenkieNL Posted February 19, 2011 Share Posted February 19, 2011 Lekker strak man ! Echt wel een klasse build ! Good luck here in this forum! Link to comment Share on other sites More sharing options...
Tortured_soul Posted February 19, 2011 Share Posted February 19, 2011 I do not like green, but your mod looks great. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 19, 2011 Share Posted February 19, 2011 Lindo your casemod is a pity that here in BRAZIL we did not find this quality so many hards Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Share Posted February 22, 2011 I love Kier and green ! Or did i already mention that ? Link to comment Share on other sites More sharing options...
kier Posted February 23, 2011 Author Share Posted February 23, 2011 Update Hello everybody, the other side of the case,(other sidepanel) did some sawning and grinding It took some time, but almost finished Have used the green acryl from the other side, never throw something away Recycling again Need to shappen the slots some more And did some more small things. Maked the cover for the display again, but now with aluminium Better then the 3mm black acryl some more grinding and sawning put the grey display in only paint the cover again and it's finished Have used the same black aluminium for the sli cover Mdpc bolts in it nothing more for this cover, think it's finished like this Also did the final placing for the led strips Placed with the uv strips a green stripe, just to remove the purple color Looks nice on the mesh panel Lines on the motherboard cover are very good visible now Need to shappen the cables some more, but almost there Thats it folks, see you next time grtzz. Link to comment Share on other sites More sharing options...
biggatomic Posted February 24, 2011 Share Posted February 24, 2011 wow ................. Link to comment Share on other sites More sharing options...
Enigma8750 Posted February 26, 2011 Share Posted February 26, 2011 Very nice Build.. Link to comment Share on other sites More sharing options...
kier Posted February 26, 2011 Author Share Posted February 26, 2011 thnx for the nice comments you guys Good luck to everyone in this competition cheers Link to comment Share on other sites More sharing options...
