pimpachu Posted March 22, 2011 Share Posted March 22, 2011 Pretty sweet, so far. I love the use of the gelly pens! very clever- and cheap way to uv enhance a case- i know it's something i'll do, in the future. Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 23, 2011 Author Share Posted March 23, 2011 Quick check to see where the cilinder is to be placed. Dremeling a slot to place it. Yup, thats the spot. Link to comment Share on other sites More sharing options...
PaPang Posted March 25, 2011 Share Posted March 25, 2011 This is for me, a verrryy crucial step. May the modding fairies buzz your imagination Frenkie, hehe! It will be a challenge but not insurmountable, if I know you well enough Cheers and Saludos Link to comment Share on other sites More sharing options...
mindphaser7 Posted March 29, 2011 Share Posted March 29, 2011 I like Half Life 2 style! And you have an amazing gallery of cases Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 30, 2011 Author Share Posted March 30, 2011 Thanx man ! Well Mike, how about this: After some extensive brain-draining I found a solution to secure the reservoir. Two threaded studs and an aluminium strip. This way to mount it to the chassis. First a solid connection connection with the threaded studs. Some nice cap nuts. Two pieces of that stainless steel tubing. To finish it off like this. Link to comment Share on other sites More sharing options...
FrenkieNL Posted April 3, 2011 Author Share Posted April 3, 2011 Next problem ( I mean ofc challenge) the flowmeter. I want to use this in combination with the reservoir. I had great difficulty placing it where I wanted too, with the standard existing in- and out let. So i mounted two 90 degrees connectors. This way, the total height of the flow meter stays within a reasonable size. Now I first need to make a solid point from the case. (attempts to mount it to the reservoir all failed) This is the way to mount it just above the reservoir. Mounted the Forex front. Sideview. Link to comment Share on other sites More sharing options...
FrenkieNL Posted May 1, 2011 Author Share Posted May 1, 2011 I have cut two large pieces of Forex for both cirkels. This connector of the waterpump is coming in one of the slotplates. There you go. Started working with the giant on/off switch. Later on this will be covered with Forex. These two wires for the pump: no way man! There, that looks so much better. to be continueed.... Link to comment Share on other sites More sharing options...
sunnyXtremist Posted May 2, 2011 Share Posted May 2, 2011 How are You Frenkie!? Hey PaPang - regards to You too... I am just sitting here and watching closely - to learn more of modding!!! (for now I have the time) Great One Frenkie... Link to comment Share on other sites More sharing options...
FrenkieNL Posted May 3, 2011 Author Share Posted May 3, 2011 Thanks man, you can teach us also a lot ! All waterhoses are connected and the on/off switch mounted solid. 'Genuine' Combine technology :-) Peeled all stickers of a Western Digital harddrive and mounted it to a Combine Transmigrator. When I modified the Transmigrator to fit the flux-deflector some nice sparks emitted! Mounted the modified HDD to the chassis. With swing-arm for easy access. There, thats ok for now. Link to comment Share on other sites More sharing options...
FrenkieNL Posted May 5, 2011 Author Share Posted May 5, 2011 I disassembled an old connector to get this rubber housing. One HDD flatcable, one piece of tubing and that rubber housing. Ofc I had to split that flatcable Now it needs a little shrinking tube and a bit of paint. Also gave the molex power a tubing and an old cable guide. There it is. So then I thought, lets test the power connections and the LEDs...... OUCH! major shortcut in one of the LEDs Completely fried ! But after I replaced it, everything worked fine. That SpinQT emits a nice red glow. Rest of the case is lit up in (steel)blue.... One LED behind the flowmeter gives a lot of light. Link to comment Share on other sites More sharing options...
