Jump to content
�O�HotRod��o
ArgOs
  • Replies 41
  • Created
  • Last Reply
Thanks
Continuing with the creation of the Hot Rod grill
I put it on your site, to see how it would look.
I remove the hard disk support.
The side
:scratch: I don`t like it, needs to another change. :sign7:
Link to comment
Great grill on the front, looks a little like my Phosphorus but in metal and of course a completely different take. Working acrylic for the grill would have been hard but metal is a lot harder!
Keep the good stuff coming.
Cheers and Saludos
Link to comment
Thanks
I decided to reduce the front 3 cm, to have a more aerodynamic appearance.
I have to cut the front again :(
I need to change everything.
look the inclination.
The logo of "Hot Rod" of side was cut.
Link to comment
I'm creating some new parts for the car. :D
V8
a new air intake. With a decoration as the vehicles of the 50's and 60's.
Remove the feet(¿?) from the computer.
prepare the base for the new feet.
I created the place to put the power button on the front.
is all for now.
Link to comment
I have complicated, and I started tertiary school that, but I work weekends.
I started with the creation of the fender, first a model in cardboard, to take measures.
Then, the most difficult, passing it to the sheet metal. :wink:
cutting and bending.
Temporarily bolted, then will joined with pop rivets .
could use a Cooler Master V8, if someone wants to sponsor my work, you know what to do. :wink:
Link to comment
  • 2 weeks later...
Great "fin" very retro! And an intriguing bump on the side cover which will surely call for a long of skillful work with Bondo to make it look right. Looking goood Argos!
Cheers and Saludos
Link to comment
  • Create New...
Important Information
