ArgOs Posted May 15, 2011 Author Share Posted May 15, 2011 the work finished is on the first page. connection to the light under the metal mesh. hotrod logo Thanks to those who supported me. Link to comment Share on other sites More sharing options...
ArgOs Posted May 24, 2011 Author Share Posted May 24, 2011 here, connected to my TV. I will use it as a media center. Link to comment Share on other sites More sharing options...
ArgOs Posted May 28, 2011 Author Share Posted May 28, 2011 "Changes out of competition " The competition ended, but I decided to make some changes. I decided to change the legs for wheels. First I reduced the length of the wheels, because they are very high and this is a sports car. Then I put a rubber between the case and the wheels. and I put them in place. Link to comment Share on other sites More sharing options...
FrenkieNL Posted May 28, 2011 Share Posted May 28, 2011 If there is one thing I would change, it is those rivets. To my personale taste, they attract too much negative attention. I probably would use 90 degrees support hinges and construction kit. Better yet is to solder it.But that takes a lot more work plus that metal tends to wobble under heat. Still, nice try man ! Link to comment Share on other sites More sharing options...
ArgOs Posted May 28, 2011 Author Share Posted May 28, 2011 Thank you Frenkie, I agree with you, but it is a matter of low budget and few tools to work. Link to comment Share on other sites More sharing options...
ArgOs Posted May 30, 2011 Author Share Posted May 30, 2011 some order. the fan change the power supply to another more powerful, but bigger. I make ​​some changes and remove wires leftover inside Good luck to all competitors. Link to comment Share on other sites More sharing options...
Oodin Modding Posted May 31, 2011 Share Posted May 31, 2011 Great job and congratulations just have to wait and celebrate the top lol greetings Link to comment Share on other sites More sharing options...
ArgOs Posted May 31, 2011 Author Share Posted May 31, 2011 Thanks you, There are very good works submitted, we will see what happens. Link to comment Share on other sites More sharing options...
KITSON CHAN Posted June 2, 2011 Share Posted June 2, 2011 Featured works! Link to comment Share on other sites More sharing options...
masbuskado Posted June 2, 2011 Share Posted June 2, 2011 Support our Brother AnG3L he deserve the second Place... http://www.facebook.com/coolermaster/po ... 1168250817 Link to comment Share on other sites More sharing options...
