MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 One of the best compliments that I Moddingviewtopic.php?f=49&t=14732 hanks friend hope you like the wolrklog, hug MACIEL BARRETO Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 Now I prepare to apply the silicone on the modeling I did in this case the silicone is such a folder, when it becomes a dry rubber. I apply the silicone around the model, leaving cover everything, you need a 5 applications for the thickness of silicon is at least 1cm. Tem que deixar o silicone cobrir tudo, para poder copiar bem os detalhes. Here you can see how the silicone completely covered the sword, kratos, so the silicone will copy all the gory details when hard. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 Must pass silicon several times to get a thick layer. Here you can see how it looks after the silicone dry, it becomes a rubber, rubber is that it will be the way to be able to work with fiberglass. Look how it releases easily from CLAY. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 I need hardly say that I'm your fan and appreciate your work, good luck for us Maciel! Thanks my broder, it is good to know there are people who admire my work, so I try to make the best possible, even without professional equipment. Link to comment Share on other sites More sharing options...
AeGis Posted February 22, 2011 Share Posted February 22, 2011 Hi Maciel Your work is very beautiful, I will take cheer. And waiting to see when it's finished. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 Here's to see the forms ready, now I use the fiberglass Agora com as formas prontas, estou colocando fibra de vidro e resina transparente, porque irei colocar LEDS dentro da espada. Notice that after the resin has dried, I'm getting the silicon to release part of FIBERGLASS. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Author Share Posted February 22, 2011 This transparent part in fiberglass, I'll use for the casemod. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 23, 2011 Author Share Posted February 23, 2011 When you take out part of the way so now we must finish. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted February 23, 2011 Share Posted February 23, 2011 Go, Go, Go Maciel I think he's out there somewhere - Yo PaPang R U ?! Link to comment Share on other sites More sharing options...
sunnyXtremist Posted February 24, 2011 Share Posted February 24, 2011 Yo Maciel, worklog photos are not working, note. Link to comment Share on other sites More sharing options...
