MACIEL BARRETO Posted March 11, 2011 Author Share Posted March 11, 2011 such as silicone rubber is one, I threw up in plaster in order to sustain. Here is the form ready to use the fiberglass, so now is put inside the glass fiber in order to use the model for the modding. Look how the form was ready to receive the fiberglass. Now I'll put the fiberglass, so I will remove the dry form the breastplate already ready for painting. Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 11, 2011 Author Share Posted March 11, 2011 After the fiberglass dries, it's time to take the form of silicone. It is this hollow part that I will use to place the motherboard and all components in the chest. Look how great the piece was hollow and made ​​of glass fiber. So now it's just the finishing and painting. his photo's to see how well the breastplate was made ​​of glass fiber. Very good. Now side by side, the part that I modeled, with the copied piece of silicone and fiberglass. Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 11, 2011 Share Posted March 11, 2011 Looking good, Maciel. What is the weight of the mold and what of the cast ? Link to comment Share on other sites More sharing options...
Alex Ftoulis Posted March 12, 2011 Share Posted March 12, 2011 You are the master of fiberglass my friend!!!! Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 12, 2011 Author Share Posted March 12, 2011 Looking good, Maciel. What is the weight of the mold and what of the cast ? The mod is light because I hear it's all in fiberglass. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 12, 2011 Author Share Posted March 12, 2011 You are the master of fiberglass my friend!!!! Thank you dear friend, I try to learn every modding I build. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 13, 2011 Author Share Posted March 13, 2011 Now I'll show you the head of Kratos. I made a Styrofoam base, not to use too much clay. Now I will cover with clay around the Styrofoam. will beginning to form the head. You can see that already is appearing the silhouettes of the face. Here is already good looking. This is already almost done. Observen veins on the face. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 13, 2011 Author Share Posted March 13, 2011 The other side of the face. finished putting the finishing touches. Looking to see if it fits perfectly. Looking from afar, to see how it looks. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 13, 2011 Author Share Posted March 13, 2011 Now I will prepare the silicone to cover the head. use a mini account in order to properly measure the silicon. 2 grams to 100 grams of catalyst SILICON. Now weigh the SILICON. Silicone mixed with the catalyst is time to cover the head of Kratos, before the silicone dries. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 13, 2011 Author Share Posted March 13, 2011 Covering the head with silicone. The silicone will copy all the details done for me. Here completely covered with silicone. Link to comment Share on other sites More sharing options...
