Oodin Modding Posted March 1, 2011 Author Share Posted March 1, 2011 This would be the other side of the box the power supply As you can notice the recycled mesh air filter car does not serve to the side walls of the box the power supply Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 1, 2011 Author Share Posted March 1, 2011 After drying the paste for patching and sanding truck proceeded to the result here http://img638.imageshack.us/img638/4296/p0711101446.jpg Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 1, 2011 Author Share Posted March 1, 2011 Tubular placing top cover As nothing is wasted here ..... We cut some pieces of aluminum left over so everything is used ... Refine details and here the result Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 4, 2011 Author Share Posted March 4, 2011 Now put a tube placed a few e-sata ports This is a slot for wiring to pass without any problem The tube where both the lit button and the stalls and - sata the slot to the same dimensions and the same measure So I left my ports and slots - sata Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 4, 2011 Author Share Posted March 4, 2011 Testing is really is just as I think if there is lol Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 4, 2011 Author Share Posted March 4, 2011 Now put the front USB ports This is the result Well since we installed front USB ports also put your DVD drive and power button Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 5, 2011 Author Share Posted March 5, 2011 Good as us because Recycling is a Fan Grills began with all 100% recycled Recycling aluminum truck body that was recovered directly from the truck collecting old iron. we have a good stretch of aluminum Now cut a square of 120 mm x 120mm Fan Grills will supply power Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 5, 2011 Author Share Posted March 5, 2011 Now we seek a design that looks more or less I modified a bit to have more air inlet The idea of this Fan Grills is to see a bit rustic metal type as abused After we have the perfect polished touch of black paint and apply bilayer This is the final result Well I guess nobody here like modding green haha well I think anyone believes are those who do not like caring for the planet Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 5, 2011 Author Share Posted March 5, 2011 Continue now with a Fan Grills 120mm x 240 mm. Same procedure as well as aluminum recycling Well this is what we have so far'll post more later and make them an invitation to make more green modding help our planet hehehe Link to comment Share on other sites More sharing options...
Oodin Modding Posted March 10, 2011 Author Share Posted March 10, 2011 More images of the Fan Grills still not finished but this to 80% This will also have a rustic finish Link to comment Share on other sites More sharing options...
