Jump to content
Lament Configuration By Tortured Soul - Finished -
Tortured_soul
  • Replies 38
  • Created
  • Last Reply
  • 2 weeks later...
Hi again friends, excuse me by the late, but i had been busy, thanks a lot to people that see this project // Hola de nuevo amigos, perdonen la demora pero he estado algo ocupado, muchas gracias a las personas que siguen este proyecto :
These are the advances of yesterday//Estos son los avances del dia de ayer
Usb 2.0 that will be use for this mod // usb 2.0 que serán utilizados para este mod:
It is giving form to the cube // dando forma al cubo:
It is joining the acrilic plaque to the metallic structure // Uniendo la placa de acrilico a la estructura metalica:
[imghttp]
At finally the base for the hd // por ultimo la base para el hd:
I would expect more advances later // espero pronto subir más avances
From Colombia with love // Desde Colombia con amor. :P
Link to comment
  • 2 weeks later...
  • 2 weeks later...
Later of search much,( in Colombia is difficult find coolermaster), i could find a coolermaster´s ventilator:
luego de buscar tanto,(en Colombia es dificil conseguir coolermaster), logre conseguir un ventilador coolermaster
me dispuse a hacer el motherboard tray de una lata de un case viejo
i resolved to make the motherboard tray of a tin of a old case
doblar
bend
lijar
sand
Remachar
rivet
yes, i know, it doesn´t totally sanding, the sandpaper is finished, but i decided change the motherboard tray cause it didn´t like me, i have another idea.
later, i will finish of assemble the cube´s structure
cute the the platens at angles of 45 degrees
Si lo se no esta totalmente lijado, se me acabo la lija , pero decidi cambiar el motherboard tray no me gusto, ya tengo otra idea.
luego terminar de armar la estructura del cubo.
cortar las platinas en angulo de 45 grados
y claro esta unirlas al cubo:
and of course join it to the cube
y agregar soportes adicionales:
and add aditional supports
+ acrylic
luego a dibujar:
later to draw
Muchas gracias a los que siguen mi humilde trabajo.
thank you very much to people that follow my humble work.
Link to comment
Hey Tortured, have to update the thread as I know you have more to show. The aluminum frame is going to be strong enough to sit on, although it may end up having things poking my rear end, hehe.
Got to hurry guy!
Cheers and Saludos
Link to comment
  • 2 weeks later...
I'm back..
bueno amigos los avances del dia de ayer son:
Adaptación de la lamina para ajustar los pci,4 discos al tiempo,luego monto las imagenes ya lijadito y eso.
*well friends, the advances of yesterday were:
Adaptation of the slide to set the pci,
4 discs while,
then mount the images and sanding and that
Diseño del motherboard tray para pintado posterior.
*design of the motherboard tray then paint it.
Cortando angulo para unir el motherboard tray con los rieles,Perforaciones para los remaches,fijación del riel,Mothertray montado,con hardware de prueba (board no prende y tarjeta de video con artifacts).
Cutting angle to attach the motherboard tray to the rails,
holes for rivets,
fixing the rail,
Assembled Mothertray,
With test hardware (board does not turn video card with artifacts)
Ya se que me extrañaban, como voy contra reloj creo que ahora si seran más seguidos los posts:
fije los angulos para la fuente (lata de fuente generica, sera removida),
*I know you missed me,
I am against the clock i think that now the posts will be more followed :
angles set to the source (source can of generic, will be removed)
pintura a la base de la board,
*paint the board´s base.
2 capas de pintura + lijado,
*2 layers of paint +sanding
Mañana (o deberia decir hoy? ) más avances...
*tomorrow( or i should say today?)more advances......
to be continued.....
Link to comment
Well, am back!
So let make the outer cube frame, dimensions 53cm height x 53cm width x 43cm length.
Cutting:
Join the pieces together:
mmmm Thank you my friend but I don't have any Welding, so I have to go this way:
Outer Cube Frame (Completed)
Setting up the fan for the Power supply:
Adaptation for wiring the power supply:
Link to comment
  • Create New...
Important Information
