AeGis Posted February 22, 2011 Share Posted February 22, 2011 Hello Everyone. The case I plan to modify will have a semi-futuristic design. But the look will still be very simple. The design focuses on different cable management.Which is had a prototype of the design of the BMW Vision EFFICIENT DYNAMICS which is the concept of the cars. The use of color on the back of the case is white and black. And designed to accommodate a water cooling system. Link to comment Share on other sites More sharing options...
AeGis Posted February 22, 2011 Author Share Posted February 22, 2011 Link to comment Share on other sites More sharing options...
shiryu_libra Posted February 23, 2011 Share Posted February 23, 2011 VISION???? reallly??? good lord, ain't gonna miss this one Link to comment Share on other sites More sharing options...
sunnyXtremist Posted February 23, 2011 Share Posted February 23, 2011 Sawadikaf friend Link to comment Share on other sites More sharing options...
PaPang Posted March 5, 2011 Share Posted March 5, 2011 Hola Aegis! Good to see you back and I think the theme is great! I hope to see another great build. Best of luck! Cheers and Saludos Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 5, 2011 Share Posted March 5, 2011 Im very curious into what your going to build for us (Vlad?). A model car with a PC inside ? Link to comment Share on other sites More sharing options...
PaPang Posted March 14, 2011 Share Posted March 14, 2011 Hello Aegis, any updates? Link to comment Share on other sites More sharing options...
AeGis Posted May 3, 2011 Author Share Posted May 3, 2011 CoolerMaster Stacker810 For my project. Design For cut Link to comment Share on other sites More sharing options...
AeGis Posted May 3, 2011 Author Share Posted May 3, 2011 Sawadikaf friend สวัสดีครับ (Sawadikaf friend) Link to comment Share on other sites More sharing options...
AeGis Posted May 3, 2011 Author Share Posted May 3, 2011 Im very curious into what your going to build for us (Vlad?). A model car with a PC inside ? NO i use CoolerMaster Stacker810. Link to comment Share on other sites More sharing options...
