Peter Brands Posted April 20, 2011 Author Share Posted April 20, 2011 Thanks guys Finally got the rubber removed. Thank god for WD40 Also made the fanhole for between the 2 psu's Just some sanding left And the extra fillports for future usage ^^ Also removed some of the backplate again, this time with a grinder Link to comment Share on other sites More sharing options...
Peter Brands Posted April 23, 2011 Author Share Posted April 23, 2011 Made the last fillport hole for future usage Almost forgot i need to sand these too so they can be powder-coated in the same color. Hmm nasty job, sanding anodized aluminum by hand, think i'll use the grinder for it. Link to comment Share on other sites More sharing options...
Peter Brands Posted April 27, 2011 Author Share Posted April 27, 2011 Quite a busy day. I brought away my desk to the powder coater. As curious as i am i asked everything Here all the uncoated products slowly move to a man who "powders" all the hard to reach spots. This guy 2 meters behind him the machine powders the rest. It's just some sort of dry powder that normally would let go. But because it's electrically loaded it's sticks to the product. After that everything goes to the oven. Here it's heated up till 200 degrees Celsius so the coat gets very hard and equal I want to use these on my backplate to hold the pci-e cards in it's place Also some new watercooling stuff to get the right looks in the desk. Cause the desk will be black soon and all my blocks are plexi, i will try these blocks in plexi too. Same here. And some extra and new kind of fittings, ill need them for future updates Link to comment Share on other sites More sharing options...
Peter Brands Posted April 28, 2011 Author Share Posted April 28, 2011 Got some new hardware i also have to build in, A Killer™ 2100 Gaming Network Card "The Killer™ 2100 Gaming Network Card delivers maximum networking performance for online games, whether you’re playing MMOs or first-person shooters. Featuring Advanced Game Detect™, Killer™ 2100 automatically classifies and accelerates traffic to your game ahead of other network traffic for maximum online game performance and a competitive edge." Off course i want to try that out, im really in for some on line gaming after such a year So first with it's cap removed next to the Gpu's. Maybe later i'll use a pci-e extender to make some space. Think i'll just make a square hole in the gtx580 backplate for the network cable. It's the only Pci-e 4x slot left. Also got a 7000rpm polisher with some sort of wax from my brother-in-law. You need to hold it tight, but the effect is perfect ! Link to comment Share on other sites More sharing options...
Peter Brands Posted April 29, 2011 Author Share Posted April 29, 2011 Finally !! And still exciting All unpacked. Very glad i coated the Bitspower radguards in the same color. Also the lianli backplate. This is how it will look. Monday ill get some new rubber tape for the desk and glass so i can lift it in the desk holder. Before the desk goes into desk holder i first wanted to polish it, but need a new polisher first, this one had no hairs left Link to comment Share on other sites More sharing options...
Peter Brands Posted May 1, 2011 Author Share Posted May 1, 2011 Small update. Changed 2 fittings, looked nicer . Sleeved some led cables, and modded the Killer 2100 in the gtx580 backplate. (Also a beer with my neigbour ) Fans also in its place. And the Ram leds in action. Think it'll look nice in the dark. Also made a small movie of the leds and the mess Link to comment Share on other sites More sharing options...
FrenkieNL Posted May 1, 2011 Share Posted May 1, 2011 Love the chrome connectors. Looks really smooth. Link to comment Share on other sites More sharing options...
Peter Brands Posted May 1, 2011 Author Share Posted May 1, 2011 Thanks Frenkie ! Waited for this picture for 8 months to see this result myself Im Very happy with it ! Bottom almost ready, still need 1 radguard. Very slowly it gets its old shape Link to comment Share on other sites More sharing options...
Peter Brands Posted May 3, 2011 Author Share Posted May 3, 2011 Sorry for the downtime of the pictures Been busy with the PSU's, needed the most efficient way for the cables and the airflow Also the loop is ready in the backside. This was a small solution to get as much as possible space for cables next to the psu. On both sides of the desk a Bitspower mini X-station for fans and molex connections. Here i had war with the cables a few times And the main battlefield. Link to comment Share on other sites More sharing options...
coolmiester Posted May 3, 2011 Share Posted May 3, 2011 Absolutely epic build L3p – i wish you good luck in the comp man Link to comment Share on other sites More sharing options...
