Peter Brands Posted May 4, 2011 Author Share Posted May 4, 2011 Such an honor to get a compliment from a such a modder I have been drooling next to your case @ Cebit 2011 Goodluck to you too man ! Link to comment Share on other sites More sharing options...
Peter Brands Posted May 5, 2011 Author Share Posted May 5, 2011 Made some time free to give a little update. Still got a lot to do this weekend to be able to update from my main pc I knew i could get it smaller ! First leds are working. Also some cables ready for under the mainboard tray. Further on with the pump-tray and got the reservoir hanging again. Used the same anti vibration rubber under my HDD's and tray as i use for my glass. I really love this stuff. Guess cable management will come later, more and more cables every day Also a small uv led stroke for the right side fans. Now also leds in the pumptops. I like it more then the regular black ones i had. This photo is with UV leds in it, but thats WAY too purple. But somehow i cant show it in photo's So i tried blue leds after that, and i liked it Next update tomorrow Link to comment Share on other sites More sharing options...
dusters16 Posted May 5, 2011 Share Posted May 5, 2011 Hey, not sure if you have seen this stuff, but it looks awesome and you can use molex connections to power it. EL Wire/Tape http://www.google.com/search?um=1&hl=en&safe=off&biw=1680&bih=925&site=search&tbm=isch&sa=1&q=EL+Wire+computer&aq=f&aqi=&aql=&oq= Link to comment Share on other sites More sharing options...
Peter Brands Posted May 6, 2011 Author Share Posted May 6, 2011 Thanks man ! Yeah i've seen it before, i was thinking about plexi beneath my trays with leds behind it. But maybe this is a good solution too. Link to comment Share on other sites More sharing options...
Peter Brands Posted May 7, 2011 Author Share Posted May 7, 2011 Took me a full hour to find the combination so i can use 2 SLI pipes for the right pump Molex plugs on the leds of the mainboard So ill be busy the rest of the day connecting all these cables Link to comment Share on other sites More sharing options...
Peter Brands Posted May 8, 2011 Author Share Posted May 8, 2011 What a long week this was Custom length BP pipes Bottom also finished. Time to fill up Just had to make some pictures. Back to getting the system up and running So the rubbers for the glass. First "backplate" in it's place. Now find a way to work away the cables for 3 screens. Wow second boot it was up and running. I really was happy with this. And im so glad i was able to disable the red leds of the Killer 2100 by the software. And some pictures of last night. This morning went up early again and it was smiling to me Also very handy those usb connections on Dells And some more night pictures. Still some small stuff to do. Polishing the deskholder and the l3p logo. And some cables need to be changed. After that ill borrow a better cam and make some better photo's. Link to comment Share on other sites More sharing options...
Kruez Posted May 11, 2011 Share Posted May 11, 2011 Great Work!!! Link to comment Share on other sites More sharing options...
Peter Brands Posted May 14, 2011 Author Share Posted May 14, 2011 Here a last update before i post pictures from the Canon camera i borrowed from my best friend AJ Sanded and polished the logo again. Quite some work. Don't wanted it to mirror to much. Also ordered some other stuff also for future projects. Different sizes of M4, next week i get M3 too Tapped it at the last moment for the bitspower thumbscrews. And ready to shoot some photo's. Link to comment Share on other sites More sharing options...
Peter Brands Posted May 14, 2011 Author Share Posted May 14, 2011 Finally finished after 8 months of modding !! Have fun ! 1 2 3 4 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 I hope you enjoyed the photo's ! There will still be some small mods inside the d3sk, but first some rest after 8 months of modding Link to comment Share on other sites More sharing options...
dusters16 Posted May 14, 2011 Share Posted May 14, 2011 Hey, good job on finally getting it finished! (for now). I know you just got a new mouse, but I would like to recommend the Logitech Performance MX. It will work on your glass/ acrylic with out the mousepad. It will even work on a mirror, pfff nearly everything. Also I noticed to have the Logitech Illuminated Keyboard, why not go ahead and get their wireless illuminated one? My fiance uses it and the MX, as her setup is next to our bed instead of on a desk. The wireless keyboard can be stored vertically and uses the same connector as the mouse to recharge the batteries (micro usb). The batteries do last quite awhile before getting low, here they only get charged maybe once a month, or every other month. http://www.logitech.com/en-us/keyboards ... vices/7288 http://www.logitech.com/en-us/mice-poin ... vices/5845 They also use the same receiver, so you only need one and use the unifying software. Link to comment Share on other sites More sharing options...
