Diegojavbau Posted February 24, 2011 Share Posted February 24, 2011 Hi , My mod will be a low budget project , so I will try to use more brain than money . , so everything you see in this project was hand made by myself. I´m in the scratch Build category , starting from an very old horizontal case , giving to it a new-modern look , some serious but not boring style . I will introduce a couple of details to make it more interesting (innovations at least for me ) I hope you like it. This is a thematic mod , inspired in the Obsidian stone (also know as volcanic glass ) Introducing the victim See you soon Link to comment Share on other sites More sharing options...
PaPang Posted February 25, 2011 Share Posted February 25, 2011 Hola Diego! Knowing you a bit better, I am sure that your theme and project should be smashing! Best of luck. Cheers and Saludos Link to comment Share on other sites More sharing options...
Diegojavbau Posted February 26, 2011 Author Share Posted February 26, 2011 Hola Papang , I´m glad to read you , thx for the support and the luck wishes , I will need all that I can get LOL. I´m very happy to be between all this mod-masters-monsters , this contest will be a pleasure for the eyes. When will you start your worklog ? I´m anxious to see your project !!! Link to comment Share on other sites More sharing options...
Diegojavbau Posted March 3, 2011 Author Share Posted March 3, 2011 Its time to cut some metal. As you see in the previous images , the back panel and the motherboard support must be removed . At the end , the hole is a lot bigger than I though it will be. A new back panel and mothertray in aluminium Fits very well , the case is very small Link to comment Share on other sites More sharing options...
Diegojavbau Posted March 15, 2011 Author Share Posted March 15, 2011 Hardware fit test time Fits well , maybe this will not be the final configuration , but is good for testing. Link to comment Share on other sites More sharing options...
PaPang Posted May 13, 2011 Share Posted May 13, 2011 Yikes diego, what happened? Cheers and Saludos Link to comment Share on other sites More sharing options...
Diegojavbau Posted May 19, 2011 Author Share Posted May 19, 2011 No time , no money Link to comment Share on other sites More sharing options...
