Jump to content
BRINK PC: FINISHED!!
TheBlackBeast=HKC=
This would be awesome to pull off. My only advice is to not draw so much from Cooler Master's existing case design and Do what YOU like.
Here is the only problem with using Sketchup, it's only good as a conceptual drawing tool. Lets say you want something cnc milled, You can only export .skp files as 2D, not 3D drawings... So all of the surface features including thickness and depth are lost... This defeats the ability to send a CNC Machinist or Machine Shop your files to have something three dimensional made. I heard from Nexxo from bit-tech that can you cna import .SKP files into ViaCAD 3D (about $70) which in turn can export it to IGES. However I don't know of anyone who has actually done it.
fyi; You'll find lots of pre-made Sketch-up PC hardware components here, http://scc.jezmckean.com/home (keep in mind the donated component measurements are not always 100% accurate)
Here is some resources that you can draw upon for outside tooling needs IF needed. Or just save the links for future project needs.
Custom CNC Machined Parts by
Centerline Manufacturing Inc.
Chris Croy (President)
Chris@CLmanufacturing.com
Ph.260-348-7400
Fax. 260-693-6356
Laser Cutting Service, Inc.
803 41st Street North
Birmingham, Alabama 35212
205-595-7070 FAX 205-595-7021
http://www.lasercuttingservice.net
Chrome Plating by Cal-Tron Plating Inc.
11919 Rivera Rd.
Santa Fe Springs CA, 90670
Phone: 562.945.1181
Fax:562.945.1181
Powder Coating Technologies
14920 28th Ave. North
Plymouth, Mn. 55447
763-559-4779
info@powdercoatingtech.com
E-MachineShop (expensive, but you're paying for convenience) FYI: You can only use their free software with their equipment!
http://www.emachineshop.com
Emachineshop gives you the ability to make parts using injection molding, milling, turning, laser cutting, waterjet cutting, bending. You can download free, easy-to-use software which they can use to design objects ranging from personal computer chassis and car parts to door knobs in metal, plastic or other materials.
For Materials, don't forget to pick up that Big yellow book of local commercial phone listings, and Google is your friend!
Probably more info then you needed, but I figured I'd cover all the basics!
Link to comment
  • Replies 28
  • Created
  • Last Reply
  • 2 weeks later...
  • Create New...
Important Information
