jj_sky5000 Posted May 24, 2011 Author Share Posted May 24, 2011 It was sunny here today and i wanted to see if the ice would melt!!! Thanks for looking !!!!! Link to comment Share on other sites More sharing options...
jj_sky5000 Posted June 14, 2011 Author Share Posted June 14, 2011 Ok I began updating the pc to more the finished product that i had envisioned. First up took off the rollers and added some cool case feet. Oh getting excited to see it match up with the red inside the case. Next up adding a window to teh side of the case added a little ecting With a chilling look Up next adding water cooling blocks to the components ( converted my 1366 Danger den water block to fit 1156 sockets) Asus Maximus Gene III and a HD5970 Thats all for now Link to comment Share on other sites More sharing options...
jj_sky5000 Posted June 15, 2011 Author Share Posted June 15, 2011 Ok a good nite of progress added the ROG logo to the front panel fan intake. Came out better than expected Finished up the ROG logo illumination on the side panel a few areas to fix but came out pretty good Installed MB VGA and began tubing fore the water cooling Thanks again cant wait to put it all back together. Link to comment Share on other sites More sharing options...
