HybridChiller Posted January 30, 2012 Author Share Posted January 30, 2012 gtx580 Classified backplates are in the house, the gpu's getting spoiled: hhhmmm sexy : Link to comment Share on other sites More sharing options...
HybridChiller Posted February 6, 2012 Author Share Posted February 6, 2012 update, first is allmost finished, need some detail work done, and made black, but it works like a sharm and no cables there anymore : Link to comment Share on other sites More sharing options...
HybridChiller Posted February 10, 2012 Author Share Posted February 10, 2012 Little update : Next copper bars are bended the same and almost on the good lenght, and 2 PciE connectors are almost ready to : Link to comment Share on other sites More sharing options...
HybridChiller Posted February 11, 2012 Author Share Posted February 11, 2012 Small update : Link to comment Share on other sites More sharing options...
HybridChiller Posted February 15, 2012 Author Share Posted February 15, 2012 little update, needs some finishing off, thirth vga adding for PhysX, bodem plate placing in, and remove dust : Link to comment Share on other sites More sharing options...
HybridChiller Posted February 24, 2012 Author Share Posted February 24, 2012 some pics of extra PhysX vga that arrived, some adjustment on fan, fan did make noise above 80%, fixed New cooling paste on GPU = Evga Frostbite, fixed New thermal pads better conductivity, fixed Cleaned out, fixed Link to comment Share on other sites More sharing options...
HybridChiller Posted February 24, 2012 Author Share Posted February 24, 2012 Link to comment Share on other sites More sharing options...
HybridChiller Posted February 25, 2012 Author Share Posted February 25, 2012 some small adjustments in rig, so really everything is how i whant it : this res comes in place of the top Coolit pump, and the one under it will be changed by a koolance PMP-400 : Bitspower Z-Multi 40mm Water Tank - Ice Red also will ad a fan red led in bottom plate for some extra air for vga's. ad some small red smoke acryl plates for finishing overal look when case is open to hide cables. And then it's really finished like i whant it ! Link to comment Share on other sites More sharing options...
HybridChiller Posted March 5, 2012 Author Share Posted March 5, 2012 Removed the two Coolit pumps and replaced them with : Swiftech MCP355 Aquacomputer top koolance heatsink Bitspower Z-multi red 40mm res Temps are little lower now, higher flow. Just need to make a nice mounting for the pump res combo (strapped for now) , make a fan in the bottom and finishing some stuff of cables and red acyl. Link to comment Share on other sites More sharing options...
