Mad_Bull Posted March 5, 2011 Share Posted March 5, 2011 Hi guys I am form Italy and this is my first international competition that I participated, and my second mod ever. I present the project "frattura" (do not ask why the name, I came this way). I have failed to remedy a case cooler master elite 335 from a friend of mine who works in a shop but the 335 has much of a problem, it's good that I have to give me. this is the case and this is a problem Despite missing the right panel and also the front panel usb, but I do not despair, I had a small project for the head but the problem did not make me change radically the original draft however, now start with the work Link to comment Share on other sites More sharing options...
j0h Posted March 5, 2011 Share Posted March 5, 2011 weee carissimo Wellcome! i'm glad to see you here my friend!!! Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 5, 2011 Share Posted March 5, 2011 Hey man, good to see you here. I like the dents in your case; whipe out the dremel and start cutting !!!!! hahahaha great to see someone who is not afraid of a challenge ! good luck ! Link to comment Share on other sites More sharing options...
Mad_Bull Posted March 5, 2011 Author Share Posted March 5, 2011 @joh ciao joh for me it is a pleasure to see you again @FrenkieNL I start very soon with cuts Link to comment Share on other sites More sharing options...
Mad_Bull Posted March 5, 2011 Author Share Posted March 5, 2011 little up, I remove the front completely, that I would do with the insertion of plexiglass the draft leads me to completely cut the top part of discovering the power for its entire length and dividing in two the left panel, the images are tests done with the board to take measurements and get a better view of the project that had in my head ... Well as a start I'm satisfied, I refer you now for updates next week Link to comment Share on other sites More sharing options...
DaveM Posted March 6, 2011 Share Posted March 6, 2011 I like the fact that that damaged case doesn't stop you from taking it on. Than sounds like something I would do. Yep thats right toss out the 8800 GTX vid card I will reflow it and use it LOL. Props on getting the free case. Link to comment Share on other sites More sharing options...
Mad_Bull Posted April 7, 2011 Author Share Posted April 7, 2011 after a long absence because of late delivery of the plexiglass, I got sick and I still have a hangover, I'll show you my latest work on the project I begin with the dismantling of the frontal cutting unnecessary parts of frontal Cardboard template Link to comment Share on other sites More sharing options...
Mad_Bull Posted April 7, 2011 Author Share Posted April 7, 2011 this is the plexiglass latecomer, the orange is uv reactive, while the smoke is a piece of scrap preparation for cutting plexiglass after I cut round the corners testing in frontal Link to comment Share on other sites More sharing options...
Mad_Bull Posted April 7, 2011 Author Share Posted April 7, 2011 smoked plexiglass will support the orange plexi, here you see the orange plexi and cut with rounded corners testing I cut aluminum angle to make support for the frontal Link to comment Share on other sites More sharing options...
Mad_Bull Posted April 7, 2011 Author Share Posted April 7, 2011 glued supports on frontal mounting frontal Link to comment Share on other sites More sharing options...
