Jump to content
Whaler's Heading, CM Modding Contest 2011 entry
Kayin
We're all back home, safe, happy and snorting. Was a simple BPD attack. Scary but manageable.
And with no further ado...
Both stays shaped properly...
and stained to match...
And black blobs on sticks...
New jigsaw!
The top hole cut, as well as most of the back done.
All right, it's chemistry lesson time. Fastest way to increase surface area on a waterblock using only household chemicals is...
First, water to passivate the reaction...
First we pour in ammonia to cover, plus a bit-not much, a millimeter or two over the top of the blocks.
Next, household peroxide. Trust me, this will be fun.
The solution starts to bubble...
Really going now...
Almost there...
And passivated out. Notice the blocks are darker?
And the base on #3 shows before on the left and after on the right. For comparison I disassembled my MIPS block.
One cleat on...
Remember our black blobs? They're plugs for countersunk holes. Just adds some completion in there.
The other side on...
And plugs in place.
The motherboard tray fits well enough...
As do the radiators. The tray needs to have some trimmed off the front though... Also, notice the PSU? There's only 12v wires. The board actually converts its own 5v and 3.3v onboard. Nifty, no?
Starting to come together...
And initial test fitment of the hard drive cage. It works well where it is, just needs to be trimmed down some. That'll get done in the next few days, so I can transfer off my info from my i7 machine, DBAN the drives ( I always do it, it just makes for cleaner installs from one OS to the other) and start assembling in the case.
Large update, but it's finally coming together now.
Link to comment
hope all is well with you and the family but posting picks of your baby in a modding forum people may think you've water cooled him, hope your little one feels better soon its a worry when they get ill young cos they just cant tell you whats wrong
Link to comment
All right, back with more.
Sorry it's been a few days, we get a 5GB/month cap out where we live. We already made it for the month, so I had to borrow the library.
With no further ado...
Cutting corian for waterblock tops...
Drilled for screws...
Base mounted...
Pegs test fitting...
And it works. Yes, it's missing inlet/outlet. That comes in a bit.
More on my mounting there...
Two...
Three...
And all four mounted to the board. Picked up new screws today to mount the block tops to the bases with, so the pegs will fit more uniformly.
And mocked up with the chipset block. It's coming together, slowly but surely.
Legs for the monster...
Mounted-the hole in the base is one big intake. It intakes from the bottom and should exhaust from the rear when I finish that part up.
Tops drilled and tapped. Told you I would...
A pause to mock some things up...
If I run it this way, all fans are motherboard controlled...
And my top window-a 13x19 slab of 1/2" acrylic. In other words, coffee table material.
Well, today the weather isn't cooperating, but I should have more to show in a day or so. Up next is cutting and fitting the corian for the top, scrimshawing it and the block tops, and waiting on my fittings, tubing, VGA block, and lighting to come in. It's all tested, and it works just fine. Also, I have to figure out where to stuff my 2 1TB HDDs. Not as big an issue as it sounds, though. I think I already have the perfect place.
Remember, red sky at night, sailor's delight. Red sky at morning, sailor take warning.
Link to comment
  • 3 weeks later...
All right, I'm finally back, after a cracked bone in my arm and FTP wrangling-there is no rest for the wicked...
If you want your sleeving to look like rope, then you need rope. Or bricklayer's twine, as is the case here.
And it's on pretty tight, as you can see here.
The power supply, sleeved in twine. You'll notice the molex and sata connectors are sleeved as though they are knots...
More detail on that.
All the PSU leads whipped together to ease handling under the tray...
Rough cut to accept the motherboard tray and show how the interior is setup.
Giving the radiator the same treatment...
Test fitting as I go...
And more test fitting...
A mock-up of the view through the window...
And aging the beckets and sleeving. On a whaling vessel, all rope would have been tarred, and therefore all of this is coated with wood stain in a color approximating pine tar.
Without flash showing more of the true color, as well as showing the parts the stain wouldn't reach, just like a regular one.
Radiator sleeving coated...
The other side coated...
The PSU cables coated...
A scrimshawed water block, ready for leak testing...
And while I have a good bit more progress, I'll let this ride for a bit for an update. I may upload more later today.
Link to comment
Back at it again, trying to get all my progress uploaded before we go tomorrow.
Getting ready for something...
Whatever it is, it involves thermal pads.
If you guessed waterblock, you got it right.
Doesn't look half bad, either. My original plan was to make the top from 1/2" Corian like the CPU blocks, but honestly I have a better plan for this. You'll see.
And here's another nice seldom-seen item-8x1 fittings, these in copper.
Fittings on blocks, and the second scrimshawed block is visible. It's a whale.
Ready to make these right for this board-it's a pain jamming in all manner of strange connectors, sometimes backwards.
Got the PSU colored up and ready to install...
Masterkleer 8x1 blue tubing...
Chipset block with fittings, checking for length of tubing...
Crabs.
Sleeved and tarred liquid neon tubes...
Brass, mocked up for the back panel coating. Will be cutting I/O and finalizing PSU mount this week hopefully, and this will be tacked down with brass nails.
The liquid neons alone...
And with the crabs, as they're chipset coolers and a light source as well.
An in progress of the interior...
The better idea I had. There's a dead spot of light in that area from the neons, this fixes it and makes the card look cool.
Gluing up the corian to the top. Yes, it looks ragged. That's intentional-remember the edges of the block I posted first? I'll be having fun with the aging on this top when I get to scrimshawing it.
And a more lined-up picture. I still need to stain the interior of that cut and clean it up a bit better, but I had to get everything attached and aligned before I started putting things in final place.
If the cracks end up too bad, I'll fix them with white caulk when I waterproof the window. This WILL be an end table, after all...
All right, I'm tired, the cat is hyper and Snort is having a deep, serious conversation with Mr. Bumpy. I'll see you all next post. This finally gets me up to date. The end is in sight, just need to keep my wits about me and my head above water.
Link to comment
  • 3 weeks later...
Well it appeared to be a fine effort but no final pics as of today means no finish unless they extend the final date. You never know! Would another week mean anything to ya'?
Cheers and Saludos
Link to comment
  • Create New...
Important Information
