MoMod Posted April 9, 2011 Share Posted April 9, 2011 great work Link to comment Share on other sites More sharing options...
Guest awadon Posted April 12, 2011 Share Posted April 12, 2011 I've started assembly. First I wanted to exchange the cooler with the block. Due to the very unusual mounting holes in the motherboard I had to adjust block. A little welding and we have such a thing:) Then I unfolded and mounted power supply. Then I've started pump assembly. I decided convert it a bit and attach a steel extension arm to minimize vibration. As you can see there isn't so much space in the middle. And that's not all I have to fit in that chamber:) Do not ask me too, who made a block and a pump. I just had them in my garbage. Link to comment Share on other sites More sharing options...
Guest awadon Posted April 14, 2011 Share Posted April 14, 2011 Some other changes I've got the liquid. Cooler I'm mounting bistable switch to be able to turn on and off the plasma balls. Here is the motherboard, and you can see CD basket. I've made a cover of the next chamber. Link to comment Share on other sites More sharing options...
Night_Flyer Posted April 15, 2011 Share Posted April 15, 2011 I 'm liking your build so far but for me giving the inside some colour would make it that much more professional. Keep up the good work Link to comment Share on other sites More sharing options...
Guest awadon Posted April 16, 2011 Share Posted April 16, 2011 Mounting the connectors. And I'm slowly doing the final assembly. Link to comment Share on other sites More sharing options...
Guest awadon Posted April 19, 2011 Share Posted April 19, 2011 Close to the end. Next stages of installation. Motherboard along with drives enclosure. Radiator without the fan. Practically all 220v electrics made​​. All relays plugged. Only fan is missing here. And this is printed circuit board after painting. In the next design going I'm to perform in this way a large number of elements. Link to comment Share on other sites More sharing options...
Guest awadon Posted April 19, 2011 Share Posted April 19, 2011 Today one more small update - fans installed. According to the rules I've choose to use Cooler Master fans 120 fans to both chambers. And in the arm I've installed 80 fan. It needed just a little edit:) It will also cool the monitor. Link to comment Share on other sites More sharing options...
Guest awadon Posted April 27, 2011 Share Posted April 27, 2011 Project completed. Pictures are big. And in some cases may look like a half of a picture. Sorry, but you must click "show this picture". More photos in the gallery: Positronic Brain Gallery Link to comment Share on other sites More sharing options...
phinix Posted May 17, 2011 Share Posted May 17, 2011 This build is fantastic, one of the best steampunk I've seen. I'm really surprised that it has only 2 votes so far:( Maybe because for some reason non of the polish email domains work in voting system WP, onet, o2 - non of them work when someone votes. I hope you'll get more votes in next 2 weeks, cause its a great project! Powodzenia! Link to comment Share on other sites More sharing options...
DaveM Posted May 18, 2011 Share Posted May 18, 2011 great job on this build I am amazed at the finished product. Lovin the brass inlayes Link to comment Share on other sites More sharing options...
