ebay69 Posted March 12, 2011 Share Posted March 12, 2011 I brought 1x 2GB PC6400 Kit Corsair Xpert Pro XMS2 a few years ago from the U.S, as this product could not be brought in this Country for my old build that I did. I am using this Ram in this New Build as it has a Display for the Temp, Voltage and Freq. On the front of the Stadium at OLD TRAFFORD there is a very large display to tell what events were coming up for people to see. These Displays will Represent this. I believe that this Ram is only one in the U.K. I have taken from my old Antec 900 Hundred Case the Floppy Dive Front Cover and cut it to place both of the Corsair Displays in it. I made up a cable and Conn. that connected the Sticks of Ram with the Displays, as the Displays were designed to fit on top of the sticks of Ram only. I brought a blu ray burner LG BH10LS30 for the build. I brought some Manchester United stickers from Ebay and Football stickers to place on the Back of the Drive and the Bottom where you could see it from the inside the case. I have removed from the drive all of Manufacture printed Logos as this would not look good on my Build by using a Special Rubber. Link to comment Share on other sites More sharing options...
Tortured_soul Posted March 12, 2011 Share Posted March 12, 2011 because 3 post for the same project? Link to comment Share on other sites More sharing options...
DaveM Posted March 13, 2011 Share Posted March 13, 2011 you might want to keep this to one thread and not fill up all the threads with the same project Link to comment Share on other sites More sharing options...
ebay69 Posted March 13, 2011 Author Share Posted March 13, 2011 I brought 4mm and 2mm copper tubing from a Local Hobby store to make the main support beans that support the main roof at the Stadium. I had cut the tubes to size and Soldered every each one 50x off of them by using a soldering iron to give me the shape of beans that were needed for the Left and Right and the main Top beans. I am sorry but I have no photos of this as I was making the copper tubes up late in the night when my Children were a sleep in bed. I painted the copper tubing in a Grey Primer first then the Painted the main White Gloss paint as what the there are at the Stadium. I drilled the right size holes in the top cover of Case to fit the Copper Beans then glued the Copper tubes into place and filled in any holes. I have included a Photo of the Main Case Hard drive bays with the fan supplied with the case. I painted the out side of this case with a Gloss Red Paint and the inside with a Gloss White Paint. The Stadiums Main Front Entrance has big white pliers and beans on the inside with smoked Glass on the outside. I replaced all of the Antec fans with 120mm Red Fans with the outer casing being see-through with Red LED Lights. I then put MANCHESTER UNITED Stickers on the Fans, as you can see them through the Air vents on the front. Link to comment Share on other sites More sharing options...
ebay69 Posted March 16, 2011 Author Share Posted March 16, 2011 I have cut out on the top of the case, the flat panel and replaced it with a Clear 3mm Plastic as it represents the roof of the Stadium. I have cut three lines into to the plastic so it looks like three panels and not one solid bit of plastic. The clear plastic is attached by four screws and not glued into place. I rewired the Asus Motherboard Bios Poster and put it underneath the clear Plastic as my photos shows this. You can easily see this as when it powered it has a bright blue display. The big Antec 220mm Fan, I replaced all four Blue LEDs with Red LEDs ones. The wire used was Red to bend in with the Red paint being used. I put the main sticker of Manchester United on the Fan unit, so you could see it clearly. All of the main input wires were from the front panel are all colored Red, these are the wires you see from the photo they are all underneath the clear plastic. I got a 10mm Clear thick Plastic sheet and cut to size and then Put Manchester United Sticker on it. I had drilled two holes at each end of the plastic to put 3mm Red LEDs and glued them into place. When powered up these lights are bright Red just like the Sign at the stadium. Link to comment Share on other sites More sharing options...
