Jump to content
Scratch build: BETA (FINISHED)
Gtek
  • Replies 20
  • Created
  • Last Reply
Hi everyone!
Project BETA.... As a name may suggest, it's going to be a secondary PC. The plan is to put together very compact, microATX based computer, capable of most every day tasks including some gaming. Also, to save even more space, no watercooling in this one (sorry). In fact the target is to use only ONE big fan for whole case airflow(excluding cpu, vga, psu fans). As I've used aluminium as my primary building material for ages now, it's time to try something new. So here is the concept in short. Aluminium chassis and fibreglass body panels. Yes, it's the fibreglassing that is new to me and this is where I'm going to start. If I can manage this part, the rest should by ok, as I worked with aluminium a lot. The colour pattern will be white and black, but probably with some extra spice, like green cabling or some other detail inside of the case.
No concept pictures of rendering at the beginnig, but the idea is: a simple, but attractive design, and I'm sure you will catch the clues quickly if you will follow the work log.
So this is how it all began.
For start I ordered some styrofoam to sculpture a model for 2 main fibreglass panels. Left and right one, both the same shape. Once models finished, layer of body filler followed to tweak the finish and than the whole fiberglassing process. And here is how it went:
time laps videos:
Link to comment
The rest is all the progress I've made till now, in pictures. In short, I attached hinges to body panels, made a front panel, installed 180mm fan, build a chassis, painted it all and installed top perspex panel, and reattached side panel... And that's the case pretty much finished. All I need to do now is to get all the internals a fit them into the case. And fire it up :lol:
Link to comment
  • 2 weeks later...
  • Create New...
Important Information
