Jump to content
THErMOnUCLeAR_2011 CM Case Mod Competition Entry( Finished )
Longhorn1000
  • Replies 70
  • Created
  • Last Reply
<> Finally..........
Finally, I could do some updates as tensions are running high and the closing date is just around the corner. So, as you all were craving for updates, here it is
So here it goes, enjoy my kinda short update..........:( but lots of effort were put into it.
Man, very hot and sunny day, but the work must go on as I promised.
First off, here are the materials that I'll be using, maybe some won't be achieved today, but I'll still continue it tomorrow. Very sure
And yes, here's the case from the last update. Note: where's the pvc?
Materials/tools
I said lucky on my last post right? well,
yes, the plank is indeed in a very bad condition, I said lucky cuz I found it in a nearby abandoned garage, made from wood and I kinda......."borrowed" one of the best planks I can find there so I won't need to buy another one. since it is still usable and a few couple pieces more of wood >< Economical and environment friendly right? reuse usable products, save the environment :yessir:
First off, I'm going to measure the length of the base of my case........
Hmm........54 cm.......
The breadth........
22 cm.....
sunbathing...........lol :lachen:
what ever, lets continue
so here's the plank,
let's tag the length and the breadth on it.
draw a line......
the breadth...
tag it here....
done
draw another line......
man, so hot......some water will do.....
sweat all over the plank..
lets saw it!!:devil:
some progress.....
more sweat, it's my hand........
about 15 minutes later
yessss!! it's out
I think the cut looks nice......
will it fit?
nicely.......
now, let's trim off the breadth......
looking good.....
almost there.....
out :D
so here's a piece of long wood...
according to my plan, I'll need 4 of those and with a length of 16 cm, sorry, not the pic
so let's mark out 16cm....
draw a line to the mark,
saw it,
very nice cut out there, i think....
some scratches......
what ever, lets do it 3 more times..
measure, mark, draw a line, and saw it.......I don't wanna put too much of pics just to show me doing the same steps.....
20 minutes later
all four of them........
lets measure the bottom again...
in this case, I'll only need 20 cm for the length and same breadth
mark it on tha plank,.....
argh......a little bit more......
yay, its out
whoa.....lots of........what do you call it?
Well then, it has been a very tired thus exhausting day. Anyways, that's it for today and hopefully I will.....continue tomorrow and next Tuesday. :D so stay tuned and thanks for following my worklog, see ya'll really soon.
  • 2 weeks later...
Hello guys,
today, I'm gonna be doing a little hammering to the planks and wood of last week.
so here's the plank I sliced last week and the wood pieces
ok, I'm gonna use 4 of these small (s)nails and 4 more other big nails for the base
2 on each wood
and here are the bigger ones
lets start hammering them 8)
last one........
done :D
And yes, I tested their stability with about....200 Ib of weigh lol.....:baaasmile
worse mistake i did ......:doh: "slap in the forehead" cuz the wood shifted a little today. well the wood's base is ---- on one side and \ on the other side.......
what ever, lets dig in and see what happens. and if I can fix it?
it actually came out pretty nice....
oh crap..........its gonna rain .....NOOOOO~~~!!!:(
well.....lets speed things up a little
it rained, but the show must go on ;)
well, at least it fits nicely
so, I'm gonna use the same breadth reading taken last week and transfer it to a thin piece of plank sliced from the piece just now
and I didn't show all the process as the rain was.........bad
im gonna hammer 2 nails on both sides of the small plank
hammer them in a little....
and walla :D
well, that's just about it.
Stay tuned :D
Well, just some pics here and I can't do any work while the lights are out....
The parts and materials that I will be using. NOTE : captured few minutes before heavy rain.....
Finally something up to date.......a hot glue gun :P
from left to right mechanical pencil, pencil leads & rubber
the bench like thing from last week......
OOoooooh.......crazy sharp razor for cutting through acrylic..:eek:
so here's my planning,
the left view , front & back view of the bench like thing. very simple
too simple I might say.....
and here comes the careful planning for 1 day ++
it says it all in the pics :D and please post some quick comments on this pic cuz I'm gonna start off cutting once the rain is over, cuz I'm runnin outta time. Thanks.
Aha, it's about 9.30 p.m. Eastern time here, rain is startin' to stop, actually it's just some drizzle.......
First off, I'm going to be measuring the length of the ....thing....
54 cm?
the width......NOTE.......the width is same as the height of the thing...!!!
20 cm
transfer the readings to the acrylic
marking
line drawn
please resize the image and sorry but I had to use flash as there's no good lighting
lets cut this babe :gunner2:
half way done.......
again.....marking and drawing.....
halfway done cutting
ok, up and out:D still, it needed some sanding....so, hows my first cut?
sanding...........again, 800 grit
nicely done
ooooohhhh, night already
still, there's still work to be done
this time, instead of drawing these lines one by one, I decided to draw all of them at once= saving time and increasing work done
so, lazy to show all the cuttings as they are the same.......here's the second one out
oops, flash...
proof.... :gotproof:
I know, its a pizza box
one more piece left,
axis-y of the acrylic ( cut)
out :D yay!!
all 3 of em'
so guys, I couldn't continue my work as the lighting gets poorer so I'm gonna continue on tomorrow's morning. cuz its labour day here LD
no need to go out :D
so stay tuned....
and yes, one more thing.
guess what am I using for the overkill fan grills? I bet you won't even know it XD try it :)
thanks for following, stay tuned and comment.
Urgh...woke up pretty late today.....9 a.m, not bad... And work is now continued at
12.17 p.m
first of all, I'm gonna randomly pick one of the 3 pieces of acrylic from yesterday.....
mark the width on the acrylic
done
cuttin' it
out :D
new one.....
hmm.....Ran out of memory, gotta delete some off the cam....stay tuned :P
ok, it's done, but still need to cut through the piece of plastic behind
done :D
now let's mark a hole in the middle
this is gonna be a long way .......
30 minutes later..........
5 minutes later......
:D
no........................................
what ever, pvc glue to the rescue :D
peel off the plastic and apply the glue
well guys, that's all for this afternoon, sure to be back in the evening, 3/4 hours later max.
see ya and stay tuned
  • Create New...
Important Information
