Longhorn1000 Posted May 2, 2011 Author Share Posted May 2, 2011 << Quick little update>> It's done you won't see a difference.........if up close, yes, you will see scratch marks Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 2, 2011 Author Share Posted May 2, 2011 so, there's more of those bad edges....... guess what, I'm gonna use scissors !! XD i mean it snap snap snap ok, that ain't gonna make a difference ....... well, I think all of us can already picture the thing speaking of which, here's some of the bezel leftovers I have u know what, I'm gonna do this my trusty can opener lol doesn't seem to work this time huh still, I'm gonna cut these parts off ( white line ) Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 2, 2011 Author Share Posted May 2, 2011 but wait, this time I'm gonna go hardcore !!!! ROAR XD a HUGE aluminum cutter scissors looks like a bird to me lol... snap snap, in less than a minute, here's the result better than expected so, the leftovers, need to snap off the top and bottom pert there, one beautiful touch Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 2, 2011 Author Share Posted May 2, 2011 and I'm gonna stick em to the acrylic, as you can imagine here's the glue gun, heating up here goes nothing 5 minutes later it actually looked better than I expected so what do you guys/gals think of my first try? oh no.......it's the end of the evening and there's still more to do.....nah, I did a lot today did i? and tune in tomorrow for more of my work End transmission.............. Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 Today, I'm about to go on an all out mission for 2 days. As usual, here are the parts First, I'll be dealing with the back part here's the piece from last monday Stick it here And I'll be using the permanent glue by Dunlop Sanding the acrylic for better grip done rinse it to remove excess dust wipe it here goes nothing Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 done.... I'll let it dry up first while I glue the wood side Here we go, nicely done few minutes later, both of them are now half dried let's hope they stick and let gravity do the following work hey hey hey, there's a new player, aluminum my trusty tool box let's mark 26 cm on the aluminum piece, a little bit more higher than the original height of the case draw the line lets cut it done lets mold the aluminum piece as same as the front panel. it fits, but need something in the middle to support it I know, those leftover acrylic will do the job I'll mark the aluminum same as the emerged block done, draw the line lets start cuttin btw, here's the acrylic I stick just now fits nicely and doesn't come off Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 so, some time, since I updated, so lets continue so here's a piece of zinc which I marked on it now, since the height of the thing is approx 21cm, I'll be doing 26cm Picked a spot to put down the spade drew 2 lines cut it out I randomly picked a spot to bend the zinc bendy bendy now for the harder part, bending a small piece.... with the help of a pair of pliers there we go, nice and clean stick the small bent piece into one of the holes on the thing and it fits like a charm still, there seems to be 2 holes on both side of the piece, now what? Just cut a piece as same as the side. But how? One cheap trick, spray paint the side on a piece of zinc and cut it a few minutes passed and the paint has dried up in the sun, ready to cut. same technique with the other side and after fitting with the main piece, there is still leftovers which means I can stick it to the main piece very easily drew a v shape and cut it out bend the cut section fits perfectly now draw lines for cutting out excess sides Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 walaa still some excess sides on the top mark it and cut it they went for a rinse and now sunbathing Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 everything dried up stick the main piece back and hot glue it nice so I sticked the 2 pieces on the main piece with the same technique used in the one before with the Dunlop glue and I couldn't show it to you guys/gals as I only have a pair of hands. Sorry after since its a bit shaky, I use those leftover bezels and bend it to fit the hole inside cut it in half and bend it to fit so here's the unstable looking housing again , with the same technique let them dry for a while and fit them in there some time later...... so here's the cutting( abandoned) i did for the first time and it didn't worked out really well anyways, i'll cut it and see what happens....... well, ain't as bad as I thought... Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 6, 2011 Author Share Posted May 6, 2011 hmm......bruises sandpaper to the rescue then well, I'm gonna try sticking on the panel sanded the side panel to stick it same technique.... some time later.... MOAR weight !! nice and stable add a little scratch/scuffed texture on the side and the middle part of the acrylic there you go, a nice looking side panel with windows ROLF ok, its time for me to take a rest, since I've been doing this since the morning till evening. C ya, and stay tuned tomorrow for more Comment Link to comment Share on other sites More sharing options...
