Longhorn1000 Posted May 7, 2011 Author Share Posted May 7, 2011 So, woke up a little early today and continued the project. Just a small one and gonna continue in the evening, about 4/5 hours from now cuz I had to go on a meeting with a few pals of mine. By the way, since most of you guys said that I posted a lot of unneeded pics, thanks for informing me btw , so here's the pics of my morning work. height and width of the attachment since I don't have a template for the radiator fans, I only knew that it has a 15mm spacing for each rad an hour later here comes the next one still, bad edges so I gotta trim em done, just need some sanding work then its gonna look lika a pros work again, I did the same measurements with the one on top. sanded both of em and ready for rinsing while waiting for em to dry up, I applied those Dunlop glues, using the same concept of gluing like I did before .........I decided to cut off some pics 2 hours later at least you guys can now picture the attachment, and yes, as everyone requested, every piece is becoming one...Finally, no more:buttkick: is needed What ever, thanks for following this worklog and stay tuned I'll be back with more later ..........End transmission ........ Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 8, 2011 Author Share Posted May 8, 2011 So I went through some plannings and cuttin last night and the last 2 hours. so here I have a piece of cardboard I did a small template to fit the side of the attachment transfer the original size to 2 pieces of acrylic cut it out and transfer the bends to it too the next morning there we go next piece as you can see, there are the bending lines done Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 8, 2011 Author Share Posted May 8, 2011 Whooohooo, I finally coped up with my cams settings....lol, hard one, made 2 options, one for daylight and one more for night scene which I can now do them at night awesome.... Anyways, here's what I did after my last post Cut out 2 pieces of acrylic 21cm by 2. something inch out BAD LIghting WaRNing Trying to figure out how to transfer my imagined size to the piece of acrylic....... duh well, do that later. Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 8, 2011 Author Share Posted May 8, 2011 Later then.......... I decided to cut a hole in the middle of the acrylic O_O so, 1 inch on the breadth and 3/4 inch on length sketched the lines an hour later...... note this pic is after the editing of the options on my digi cam.......lol DIGI on 1155 boards XD continue on next piece. a few hours later.......... a very sad lost........ like a body after an autopsy broken into pieces by accident........I swear it wasn't me!! there we go.......a very sad ending on my last post of the day........still, the SHOW MUST GO ON....I'll try getting another piece of acrylic from the remaining leftovers ...... Thanks for following sob":( Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 9, 2011 Author Share Posted May 9, 2011 So here's why I couldn't cut the acrylic properly yesterday, its because of the blade was already blunt........duh So I went down to the store and bought a new blade just around 1 dollar, very impressive price and fitted it to another piece of wood by the way, how are my camera effects? so here is the leftover piece sketched out in less than 10 minutes cut off the middle part in this case, I'll be only cutting the middle part and the left side and left off the right side, as shown (pointed with scissors ) ok, its bend and broken, I had to break it to get the middle part off but some pvc pipe glue will do so, here's a small update from me for today stay tuned tomorrow for more small updates C ya Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 11, 2011 Author Share Posted May 11, 2011 Sorry for the delay guys, but the internet was just not working yesterday but it finally went well just now and I'm so glad to tell you that, MOAR updates!! NOTE: I did this yesterday so here's the old piece of acrylic which was bent and broken finish it with some pvc pipe glue and used something as a weight .....:kookoo: here's the piece of acrylic which I cut down for the side panel.........scary edges, so I didn't wanna use it I decided to use one of my leftover acrylic let's heat up the glue gun meanwhile, I'm gonna be sanding these acrylic well then, let's start welding Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 11, 2011 Author Share Posted May 11, 2011 cover up the holes since it didn't worked, the pvc gluing final touches there we go, and I'm gonna cut off the excess sides as shown but first, I'll be transferring the length and width of the piece to another piece of acrylic...... well, let's cut if off well then, sand another part welding...... done creepy..... the side I'm cuttin off done 2 of them, does it look alike ooh....scary edges cut them off and sanded it a little no more scary edges , believe me, you won't see the difference after it's painted Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 11, 2011 Author Share Posted May 11, 2011 let's try fitting it to the case and see how it goes this one is for the right side and the other one for the left side looks awesome on the attachment now, I'm going to make a block on the side of it to cover it up measure it x marks the spot approx 14.5 cm here i have a piece of white yellow cardboard my plan drew it out the height what bout' that one? Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 11, 2011 Author Share Posted May 11, 2011 mark it and according to my calculations, there may be one more piece which measures 12.7cm there we go. so guys,I'll be back with more tomorrow since its late here. See ya Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 12, 2011 Author Share Posted May 12, 2011 WARMING!!WARNING!!WARNING!! UPDATES coming in the next1.5 hours...... Stay tuned Link to comment Share on other sites More sharing options...
