Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 Oohh....First update session of today is about to end now the other side again :D looking better and better more clear coat dried up and.......what am i gonna do with this.....it seems......lonely.....cold XD the pvc pipes are done sticking no ideas at all... dried up...... I've got plans for ya a shiny black coat of paint somethings about to happen......O-O??? tadaa gonna let it dry up first while looking at the fan grill......I got an idea the two plain grey sides turn into dried up and ready for exposure added some special effects looks nice but with some more special effects, much better ok then, this will be an end to my afternoon session. be sure to check back in the evening See ya'll Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 ok, couldn't finish it in time. But at least I finished what I wanna do today some holes.......not tight enough....had to fill it with glue meanwhile, I've got plans for the other piece yes, I'm gonna place the bezel into it and stick it for sure done I don't know if you can see the big hole bezel or not... paint matte black ready for the other piece done and what I have left to do is cut off the bezel........ and it equals to the big holed bezel painted black on both sides and weld it to the bezel and there you have it........2 bad-:) side attachment It's getting dark really quick here so I decided to do a little bit more first, I wanna fill those holes and scary edges with glue and do a little paint job matte black used some dark grey as the back intake sorry for the delay....... but although the post might seem to be short, it had token me hours to finish the bezel thing. Hope you enjoy todays post and keep following as tomorrow is our grand finale !!!! Finally, this is going to end Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 so, screwed the fan to the case to make sure that it doesn't slip fit the pieces to the case measure the width of between the sides approx 9 cm but I made it 11 cm so it will fit inside of them clever thinking, cutting it out with a bottle attached to the back of it fits perfectly off for some paint job dark grey meanwhile, get some leftover pieces of card drew the height and cut it Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 match it till the end of the case mark it and cut it out going to fit another piece at the back of both pieces ok, change of plans...., I'll use the leftover of the lego box again find a piece of cardboard ( leftovers ) and try to fit it there fits nicely and stick it there but hey there's more pvc pipes I'll try fitting then there to cover it up fits perfectly looks nice too then, paint it with dark grey again which means that I'll have to modify the pieces again?? added some textures to the pipes and paint the lego boxes too, where I'm pointing is going to be covered with yellow paint and this one with matte black there my pics end here for now, continuing my work right away Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 paint the inside as well I'm gonna cover up the painted area with some tape so does this one aha, carbon fiber paint scheme again both of them covered up and ready for another coat wooooo...... wrap it up paint it in grey begin our enhanced painting since I did the first coat 15 minutes later........ the paint is revealed and didn't gave a good product lets do it the old way, cover it up nice give it some paint effects and some clear coat this one too ahh, before I forget, the last 2 pieces with grey cover them up, including the newly coated clear paint . Nice XD Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 As you wish XD so this is from the evening till late night lol 2 pieces of the cut out card looking nice I can see the finished look already got a new tube of glue ooh......nice effects done so em, the hole ( sorry, for that, loast my dialog going to stick the pvc pipe to it done Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 fit or not? so here's a piece of bezel which is leftover from last time's cuttings and paint it in matte black the 2 pieces of cards with added effects I bet you think its acrylic or metal XD cuz they really looked like it XD and again, the leftover bezel with stripes going to fit it into the hole done going to stick the card put a weigh on it to make sure it sticks properly looks awesome and see the hole there, I'm gonna do something to it remember the two pieces of acrylic I left before? the one which is sanded (left) and another one known as X marks the spot fit them here sand mr x too and give them a paint job Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 so the back of the attachment with added effects and a coat of clear paint the 2 pieces of acrylic dried up and added effects and clear coat ok, dried up looks fantastic this is one however is the intake of the attachment so here's the cut out for the painted bezel I did just now, and I wanna fit it horizontally to the top some double-sided tape will do the trick sticking it there while I weld it done welding aha, back to the original case Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 painted it with shiny black color currently around 10.25 p.m when I'm painting so, it looks great some grey and yellow paint for the furnishing of the case and effects done, you might not be able to see them in some pics a clear coat so, a piece of acrylic used for the front panel of the attachment sand it and paint it Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 alright.......the pics are done uploading so, from right to left wires......screws and all that good stuff case fans mesh bezel and HDD slots DVD Slots , PCIE Brackets tha big guy wrap both ends of the wires for painting 3 of them black and the other 3 in yellow painted the fan yellow the stock 120mm fan that came with the case matte black while waiting for it to dry, the piece of black painted acrylic is welded to the front of the attachment Link to comment Share on other sites More sharing options...
