Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 back to the brackets....2 yellow, 3 black for the HDD cages so does the tool-es dvd brackets the top side painted black...... the one with power button http://www.bing.com/images/search?q=haf+922&view=detail&id=9CC37C5BF74A9AF7044573BF3982BB9BE4A1BE64&first=0&FORM=IDFRIR the original bezel? meh, leave them there back to the attachment a piece of white card to the top fan overkill fan gril nicely welded front panel nicely fitted fan placed in outside, a pre-cut piece of card which matched the one before painted matte black and a nuclear logo on top Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 the nuclear sign is done, and some clear coat are added front panel placed in the sign is welded to the front attachment again with another piece of acrylic I randomly cut out a piece and trimmed it so that I can fit it to the back overkill fan grill place a 120mm fan and make a hole outta it the hole is out and having a paint job Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 I won't be here for the next hour and 30 min. Soccer game. wow, you are one busy person btw made holes with the pre-made template and done.....but hey, there's more. Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 Ok, finally .................its here.......... So, the plate is now mounted and welded to the overkill fan grill sadly, I gotta leave some space there so that it can fit grr.........looks mean Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 The Teaser Trailer.............lol, better off like slideshow to me TheRMonUCleAr is finally here what you're about to see is real....... NOO, doesn't look good enough, going to remake it tomorrow since I still got some time left. final impression..... so, since I'm going to modify a little and fit my pc parts in there, please check back. Btw, please vote for me. Sorry if I made any of you angry and frustrated some of you. One word, I'm so sorry for the inconvenience. Still, please vote for me( depends on you) And I would like to thank all of you who followed my long post and giving me the courage to move on even I met some difficulties. Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 15, 2011 Author Share Posted May 15, 2011 enjoy Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 16, 2011 Author Share Posted May 16, 2011 Whoa.....that was not good. So , I did some updates early today and here they are NOTE : These are only the finished pictures of the mod. Check the post before this for the work Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 16, 2011 Author Share Posted May 16, 2011 the custom overkill fan grill of min and before I forget, I did loads of paint job just now and yes, the internal is finally covered with a piece of matte black painted acrylic. Function, prevent the heat of the psu from rising and better cable management. I'll show you when I fix in the pc components removable by the way all those wires gone aha, cheap trick the fan...... top 200mm fan Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 16, 2011 Author Share Posted May 16, 2011 internal paint job so, the overkill fan grill for the top 200 mm fan is actually removable if desired for cleaning and replacing functions oh yes.....the attachment there's enough room to fit 6 single rad, 3 double rad and 2 triple rad. Unfortunately, they are however limited as it can only fit 120mm fans and no, NO quad fan rad. Remember what I said before, the holes are cut out as same as the 100 mm fan's size cuz I'm gonna make it tool-es . Example, you have a triple rad, and you just snap it in, no screws, and you're done the back vent for ventilation reasons which I can't yet solve and back to the case so, here are my post for the completed work and vote for me please and later, check me out as I fit in all the pc components To VOTE : go to click http://casemod2011.coolermaster.com/contestant.php and click Tower, and find my project name and you know what to do . Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 16, 2011 Author Share Posted May 16, 2011 Please comment too Link to comment Share on other sites More sharing options...
