coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Well, time to make a whole new top cover for the rad box as i won’t be needing the power/reset button and just wanted something that looked a bit different as i’ve never really been to keen on the look of the standard 840 fan grills. Got one large piece of 7mm alu which will cover the entire top – all i got to do is round off the front to mimic the original, then cut the vent in and finally chamfer the edges. Lets see if my little B&D jigsaw can cope with 7mm alu Still got to draw file all edges and put the 45 degree angle on there but time and cold beat me today Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Well after humming and harring about which pump/reservoirs i was going to use, the final decision came down to what would actually fit. Due to the placement of the bottom two 240 radiators i'm going to lose at least one drive bay, probably two and given i'm going to be running three loops it came down to a couple of RP-450X2's. I got to say my initial impression of these is nice but those logo's just had to go so set about making them fit in with the rest of the mod. I had to ditch the original bezels and black M3 hex bolts and replace them with slightly shorter countersink ones so once the plexi had been countersunk, the heads would be flush to allow my new hand cut bezels to mount directly to the plexi. The last couple of mock-up shots show how they fit in with a wide screen TFT just below - obviously they will be powder coated and painted in the not to distant future :hip: Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Got the side panels cut down to size for the rad box and then went about fitting four flush mount vents using the mesh out of Bitspower rad grills and used the actual grill as the template to hand cut the four openings pretty much as i did a while back on a Corsair 800D mod which gives that kinnda simple but effective kind of look and should look good with the red LED fans behind. Just got to do the other side now and then two in each side of the main case but i think i'll concentrate on getting the rad box finished before moving onto the main chassis Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Well i just turned the standard 6 drive bays into 4 to allow the two radiators to mount below in a separate little rad box. Sounds easy..........well it was really but i had to be double sure of all measurements while cutting down the original drive cage and also while folding the new rad box as 1mm out and it would throw the entire chassis out but luckily my measuring skills didn't let me down and everything lines up perfect and square I'm trying to get everything finished so i can go about stripping it all down and getting it to powder coat by Monday or Tuesday. Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Still a canny way to go but i just thought i’d show you this nice neat little hose routing from top to bottom of the chassis which turned out pretty good and a few other random shots of where things are at the end of the day Got all the chassis back from powder coaters at lunch time today in totally flawless Carbon Black to match the Carbon Bitspower fittings and set about getting it built back up which is the bit i like best seeing it all come together. Anyway, my life is currently on hold until i get this complete as it starts its journey to Germany for CeBit on the 22nd so best get my skates on Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 Got the top hand made bezel fitted to the top chassis with the power / reset and LEDs all mounted and grill installed. Best part of the day though was hose routing both the motherboard / RAM loop and the CPU loop - both turned out really well considering the amount of hose involved so only the GPU loop to do which is pretty straight forward but still waiting on cards to turn up but apart from that, i seem to be making good progress Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 I got to give my friends at EVGA a massive shout for getting me some graphics cards out at such short notice They are the EVGA GeForce GTX 480 Hydro Copper FTW which fill up the SR-2 board real nice. I'm just not sure if the Coolermaster 1200 PSU will be able to handle all four cards and as the chassis needs to be starting it journey to CeBit this weekend i simply won't have time to test so not sure what to do for the best. I think the best thing to do is install them all and sort it out when it gets back home as it won’t be running anything on the booth, just sitting there looking pretty. Looks very nice though Sorry, i couldn't resist but don't they look nice with Carbon Bitspower connectors Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 With a bit of luck i should get the cards all plumbed in and get the system fired up tomorrow but for now just some random pictures Link to comment Share on other sites More sharing options...
coolmiester Posted March 29, 2011 Author Share Posted March 29, 2011 And some final pictures Link to comment Share on other sites More sharing options...
Fotes Lykos Posted March 29, 2011 Share Posted March 29, 2011 Nice work I really like the idea of your stacked design. Link to comment Share on other sites More sharing options...
