d0g Posted April 24, 2011 Author Share Posted April 24, 2011 On the left is an overclocking "dashboard" as named by MSI. It came with the MSI big bang trinergy mother board. It was ment to be an external hand held unit, but I will be installing it in the floppy bay. I took my old floppy drive apart and used the bottom as a main support for three backets, one up-down, one in-out, and one side to side. Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 After installing the dashboard in the floppy bay Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 The grill on the left was cut from a new cookie cooler. The one on the right was from the side of a circa 1950 water cooler that was refinished with epoxy primer, then basecoat clearcoat black metallic. Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 On most of the aluminum I started the refinish process with 360 grit on a da sander Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 Then water sanded with 600,then 1500, and finished sanding 2500 grit Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 After final sanding I polished the aluminum with heavy duty rubbing compound, then Flitz aluminum polish Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 Here we have a Cooler Master 200mm fan, custom grills and corresponding hardware witch will be placed in one of the back doors. Link to comment Share on other sites More sharing options...
d0g Posted April 24, 2011 Author Share Posted April 24, 2011 The big 200mm Cooler Master fan installed Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Polishing the polycarbonate frame Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 I spent a little extra time polishing the frame because it is up front and in your face. Link to comment Share on other sites More sharing options...
