d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Original Cooler Master aluminum drive bay covers to finish off the drive section Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Power supply assembly Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Power supply would not fit on the support rails. A generic power supply was used for measurement that must be around a 1/16" smaller than the Corsair. The new power supply support is made from solid 1/4" aluminum that has been drilled out for weight reduction. Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 I simply rivited the old hollow rails in place, but the new solid support plate had to be tapped. Then the screws were thread locked. Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Some cutting and filing to accommodate the 850 Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Proper fit for the unit and its harnesses Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 Custom made brackets made to hold wires behind the hard drive bay Link to comment Share on other sites More sharing options...
d0g Posted May 3, 2011 Author Share Posted May 3, 2011 and the back wall backets installed Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 Where the front was,is now the right side door Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 This door will hold a Cooler Master 200mm fan Link to comment Share on other sites More sharing options...
