d0g Posted May 10, 2011 Author Share Posted May 10, 2011 Here is the heavily modified Mother board tray. The upper right hole will allow the 8pin power wire to pass though. The back originaly housed one 80mm exhaust fan. After cutting this area, it is just big enough to stack two 80mm fans now. The large hole in the middle was cut to gain access to the back of the mother board to ease mounting of the processor. The round holes were cut for ventilation and center the rear 200mm fan. The angles will be mounted on the back and will channel wire around the fan. I also made an extension that will be attached to the right front. This extension will allow the main power harness, sata, power switch, and video card cables to pass though for an ultra clean look. My goal is to hide as many wires as possible. Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 The tray facing front with the extention mounted on the right (more holes were drilled for the vc and switch) Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 The back of the tray with angle mounted acting as conduits for harnesses Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 The military grade mb. (no aluminum caps) look closely, not one. I had two caps burst on me over the years. All boards should be made this way. Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 The mb with the tray assembly Link to comment Share on other sites More sharing options...
d0g Posted May 10, 2011 Author Share Posted May 10, 2011 Mother board mounted with I5. Here you can see the 8pin power cable, the first of many carbon fiber sleeved cables. Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Custom cut cpu and gpu temperature guages mount assembly Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Installed temp guages (the cpu will light blue, gpu green) Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Custom cut backet for rear fans exhaust assembly Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Rear 80mm fans installed Link to comment Share on other sites More sharing options...
