brinkz0r Posted April 11, 2011 Share Posted April 11, 2011 That's one solution, I just used an usb > serial adapter chip to create a signal for a HD44780 lcd and connected it to an internal usb header Link to comment Share on other sites More sharing options...
Robchiz Posted April 13, 2011 Author Share Posted April 13, 2011 That's one solution, I just used an usb > serial adapter chip to create a signal for a HD44780 lcd and connected it to an internal usb header Yes i know about that solution, but i can't use internal usb header because i use that port's for front panel usb. Also using usb for LCD is complicated on LinuxOS (LPT and linux much easy for me). Link to comment Share on other sites More sharing options...
Robchiz Posted April 13, 2011 Author Share Posted April 13, 2011 LCD and sensor power button attaching to front panel with hot glue. Successful Power button and LCD test (with Atmega) : Link to comment Share on other sites More sharing options...
Robchiz Posted April 13, 2011 Author Share Posted April 13, 2011 Assembled LED lighting for 2 USB ports on front panel: Atached USB port (with rivet) to side panel: Link to comment Share on other sites More sharing options...
Robchiz Posted April 14, 2011 Author Share Posted April 14, 2011 Received PicoPSU so small and so good..... but wait, where is P4 connector ....after little PSU modding and case semiassebling, system is ready for test run. Link to comment Share on other sites More sharing options...
Robchiz Posted April 16, 2011 Author Share Posted April 16, 2011 Inside case not so much space, so i made 2,5 inch HDD holder from plexiglass and HDD fit just perfect. Also added internal bluetooth dongle: Link to comment Share on other sites More sharing options...
Robchiz Posted April 17, 2011 Author Share Posted April 17, 2011 Stock cooler make to much noise, so i remove him and add Cooler Master fan, also slow down rotation speed 50% (BIOS option). Now northbridge and cpu is cooled without noise: Link to comment Share on other sites More sharing options...
Robchiz Posted April 22, 2011 Author Share Posted April 22, 2011 First fully assembled case photos: Link to comment Share on other sites More sharing options...
Robchiz Posted April 27, 2011 Author Share Posted April 27, 2011 More photos: Size..... Link to comment Share on other sites More sharing options...
