Jump to content
Scrach mod: "Simple is not Simple" by socolate from Vietnam
socolate
Hi all !
My name Nguyen Linh Bao. Nick name: socolate. Iam from Vietnam.
My english not well. So that, if you don't understand any, iam sorry so much. I use goole translate first, my sister will update my text after i finish project. Thank you Google translate :cheers:
Iam not pro modder, but i like mod. And i do what i like, although it is hard, i will do it, and finish. If i not win :toothy4: iam so happy !
I don't have plan to mod case, so that, i work by think, what i think - that i do.
Project name: "Simple is not Simple".
Project is split to 12 part. Pictures will update by part, so that, it easy to track
Part 1:Material and Tools
Part 2: Body
Part 3: Side Windows
Part 4: Tray Main
Part 5: Mask
Part 6: Roof
Part 7: Bottom
Part 8: I/O
Part 9: Conect
Part 10: Finish project and edit my text ( my english not well, so my sister will edit )
Iam design, i need xtreme workstation, and Z800 is my best choice. But it only 4 hdd tray, and i have 16 HDD full data ( liberary for design and film editing )
And this is HP Z800 - Xtreme Workstation
4hdd only
Modul
Link to comment
Part 2: Body
Get a rule od shape alu
Split to more
lục trong đám này
ra dc 1 mớ trụ main
lựa 7 con đồng bộ
đo cỡ ren
lôi đồ chơi ra, í lộn, ko phải tool này
SAM_0823.JPG mà là cái này
taro
ban ngày lo cày cuốc, toàn làm ban đêm, cởi áo cho mát
cái khung case
taro xong gắn main lên
gắn vô case chơi
Link to comment
Part 3: Side Windows ( including left - right - top - bottom - front - rear
Bottom is first:
Get a side window of alu case server made bottom
Side out
Side in
It easy to side
Left window
Remove bulong
Remove splint
Test
Test in
Not good :( it open a slot
Bottom of window
Now, temporary is this, i will fix bug now
Fix bug now:
Bulong is this
I cut a groove, and use anklet stand by barricades
Yeah :cheers:
Continue 2nd and 3rd bulong
Side in, oh, verry good :D
It easy to side, easy to do :P
Bottom of window
Over view
Yeah
Left window is ok, continue to do right, it same same
Link to comment
I will translate to english soon !
TRAY MAIN HP z800 ko chuẩn, nên hÆ¡i mất thá»i gian tí
tray main số 2 chuẩn full ATX và HPTX nên nhanh chóng hơn, vảo việc thôi
vẽ 1 bản vẽ = corel trên pc, cắt laser 1 cái rập full E-ATX
lấy bút làm dấu trên miếng nhôm
ta dc như thế này
taro ren
quay lại với tray main z800
gắn 1 hostwap SAS vào
đầu tiên là ướm thử cái hộc
gắn thêm cái tay cầm để kéo tray main ra & đút vô
cái tay cầm thì wa nhanh gá»n, khoan 2 lá»— vặn ốc là xong
gắn lên case xem nào
gắn thử cpu, ram vào main z800 test
test xong, main chạy good, ko bị sứt mẻ, hehe
tiến hành mod dây cho nó
đem đồ chơi ra, chủ yếu mỠhàn, dây rút nhiệt, dây diện nguồn
mod xong thì thế này
1 búi dây ( 18pin main - 10pin ram - 8pin cpu - 6 sata - 6 ata - 1 ide - 4 đầu 12v xài fan - bơm - đèn.., 2 đầu pci-e 8 pin)
còn típ
Link to comment
  • Create New...
Important Information
